5 members (Hotrod Lincoln, Gray_Ghost, 78buckshot, Pete O, 1 invisible), 309 guests, and 6 robots.
Topics128,156
Posts1,057,021
Members48,460
G Online: Content
Hi Everyone,
1953 Chevy 3100 with 235 and original 3 speed transmission.
I'm getting the replacement engine ready for transplant into the truck and have installed the clutch cover and flywheel. I am installing a new clutch assembly and the instructions defer to the manufacturer for how much torque to apply to the bolts that mount the pressure plate to the flywheel. I've searched the shop manual, factory assembly manual and the restoration pack from GM and can not find a torque spec for those bolts anywhere.
So that's my question. What torque setting should I use when tightening down the bolts?
Thanks in advance.
Mike
1953 3100
The Gray Ghost
My Project journal
Crusing in the Passing Lane
Torque values are determined by bolt diameter, can be found on charts. Use a .375" drive ratchet, short handle, after one has twisted off a few bolts, one will get a feel.
Ed
G Online: Content
Ed,
I was not aware of that. Thanks!
Mike
1953 3100
The Gray Ghost
My Project journal
Ed,
Was the torque setting/value based just on the bolt size (did/do all grades of bolts in the same size have the same torque valve/setting)?
Also, same setting for brass/steel/stainless?
https://www.boltdepot.com/fastener-information/materials-and-grades/bolt-grade-chart.aspx
https://www.boltdepot.com/fastener-information/bolts/US-Recommended-Torque.aspx
Of course not, different torque values for different grade of bolts, brass, Al different, clutch bolts are grade 5.
Ed
Don't forget to locktite the threads to prevent oil from leaking past the threads.
J Online: Content
