0 members (),
389
8
Mod | | | Forums66 Topics128,159 Posts1,057,039 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 518 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 518 | Hi Everyone,
1953 Chevy 3100 with 235 and original 3 speed transmission.
I'm getting the replacement engine ready for transplant into the truck and have installed the clutch cover and flywheel. I am installing a new clutch assembly and the instructions defer to the manufacturer for how much torque to apply to the bolts that mount the pressure plate to the flywheel. I've searched the shop manual, factory assembly manual and the restoration pack from GM and can not find a torque spec for those bolts anywhere.
So that's my question. What torque setting should I use when tightening down the bolts?
Thanks in advance. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Torque values are determined by bolt diameter, can be found on charts. Use a .375" drive ratchet, short handle, after one has twisted off a few bolts, one will get a feel.
Ed
| | | | | Joined: Sep 2010 Posts: 518 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 518 | Ed,
I was not aware of that. Thanks! | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Of course not, different torque values for different grade of bolts, brass, Al different, clutch bolts are grade 5.
Ed
| | | | | Joined: Mar 2010 Posts: 10,305 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,305 | Don't forget to locktite the threads to prevent oil from leaking past the threads.
| | | | | Joined: Sep 2009 Posts: 123 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 123 | | | |
