| | | Forums66 Topics128,100 Posts1,056,515 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2006 Posts: 250 'Bolter | | 'Bolter Joined: Mar 2006 Posts: 250 | I changed out the rear spring stack/axle u-bolts on my new to me truck as the originals were severely corroded. I am not sure how much to torque the nuts to though. It seems like I can keep tightening them and while it takes a bit of force, it doesn't seem to get any harder as though something is stretching. Is there a torque spec for these? Or do I just make them good and tight? Thanks for the comments!
1950 3600 1951 4400 Gazz
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Torque values are based on bolt diameters, shackle bolts often have to be taken up until really tight because of slack.
Ed
| | | | | Joined: Sep 2012 Posts: 57 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 57 | You should be able to get the torque spec from the mfg of your u bolts. I use an impact and run them down until it can’t turn anymore. But I am doing this on semi trailer u bolts. Also u bolts are supposed to stretch as they are tightened that’s why u aren’t supposed to reuse them. I say if you can still turn them keep on going they will not break.
Dan
| | | | | Joined: Jul 2000 Posts: 2,196 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,196 | Torque specs are in the shop manual. My manual is for 1954, but I expect 1951 was the same. For a 4400 (1.5 ton), the spec is 210 to 235 ft-lbs!
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Mar 2006 Posts: 250 'Bolter | | 'Bolter Joined: Mar 2006 Posts: 250 | Weird, I know I wrote a reply to this a day or two ago but it is not here! In any case, I did find specs in the manual which I believe were 70/90ft/lbs. Then my mechanic friend said he was taught to tighten them until they ring nicely when struck with a hammer or something. He learned this from a place that specialized in automotive / truck spring replacement.
