1 members (Otto Skorzeny), 52 guests, and 0 robots.
Topics128,092
Posts1,056,040
Members48,433
#1330571 10/20/2019 11:06 PM
Trying to dial in my 1957 rebuilt 235 installed in my 37 1/2 ton. Checked timing and is on the timing mark. Compression test is around 140 on all cylinders. No vacume leaks and holds around 12 lbs until back fire in carb. Have 2 carbs and both seem to do the same thing. If you hold hand over intake on carb with air cleaner removed seems to run better and less back fire in carb.
Going to remove valve cover and check clearance on valves tomorrow. Looking for any thoughts about my issue. Thanks for any help you can give me. Bill
1937 GC
It could be a sticky intake valve.
It could be one of your carburetors is dumping raw fuel into the intake and then into a cylinder or two, causing a delay in combustion, whereas combustion is occurring while an intake valve is open.
Disable one of the carburetors and see how it runs. If it runs the same or worse, disable the other carburetor (enabling the first carburetor, of course) and see how it runs.
You could make a carburetor base gasket without a center hole in it for this test.
Carl
Start here. Rochester’s can be a bit of a pain to set up.
http://www.inliners.org/tech/tech4.html
Carter YF carbs are a better choice if you want dual 1bbls. A pair of 1974 Ford pinto Weber progressive 2 bbls are even better.
Mike
Maybe I stated that wrong. I only have 1 carb on engine but have a extra carb that I tried. Both have some back fire so that is why I think it is not the carb. Bill
1937 GC
I misunderstood.
Mike
Improper valve adjustment (valves too tight) is a cause of pop back through the carb. If it is a solid lifter cam set intakes to no tighter than .006 and exhausts .016. Hydraulic lifters go 1 turn past zero lash.
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
It has hydraulic lifters
1937 GC
How were they adjusted initially?
Mike
Bill, with hydraulics, I take up all the clearance by spinning the push rod between the thumb and forefinger, then when the push rod ceases to spin go only 1 turn further. Assuming you have the crank in the proper position for adjusting said valves and the lifters pumped up.. Point is, intake valves that fail to close all the way will cause the popping back through the carb. It would be considered to be one of the first things to check after assembling one's engine.
1953 Chevrolet 3100
In the DITY Gallery
1964 GMC 1000
Drag6, were those pics for me? As per your Pryor question, the valves were done after assembly and Pryor to running the engine.
1937 GC
No. Wrong string. I think I am with the others. Readjust the valves first. Then double check your timing, then readjust the carb. Doing those three things costs nothing more then some time and eliminates a bit of low hanging fruit. Next, check for vacuum leaks, including at the vacuum advance. Make sure the vacuum advance is actually working. If not, it may have a ruptured diaphragm and will need replacing.
Mike
OK, now its clear that you only have one carburetor (my mistake, not yours).
If we adopt my mantra of "Its never the carburetor", then its time check everything else besides the carburetor.
It could be as simple as one lifter is set too tight, preventing a valve to close.
I would start by removing one spark plug at a time while the engine is running. You will find the offending cylinder when the removal of its spark plug causes the backfire to stop.
If you introduce air at the spark plug hole of the offending cylinder while both valves are closed, you will be able to hear air escaping through the carburetor if the intake valve is set too tight.
Remove the valve cover and see if backing off the rocker arm screw stops the air leak through the carburetor.
Will be checking valves one day this week and will post what I find. As per vacuum advance it is working and have checked for leaks and found none. Thanks for your help. Bill
1937 GC
Checking valves tomorrow night and have been thinking about my back fire in carb issue. It is a 57 235 with a 54 flywheel so it matched up to my stomp starter. Could I have install the flywheel wrong? I seem to remember that it would only fit one way. Is that correct? Maybe I am over thinking this!!! Thanks for any help
1937 GC
One way only on the flywheel
1953 Chevrolet 3100
In the DITY Gallery
1964 GMC 1000
It's been 1 1/2 year since I put it together so could not remember for sure. Thanks for putting my mind at ease. Bill
1937 GC
