1 members (1 invisible), 105 guests, and 3 robots.
Topics128,024
Posts1,055,395
Members48,422
#1330622 10/21/2019 11:39 AM
Will a Unity S-18 light work on an AD truck? Does anyone know where I could find a replacement bulb similar to the one in the link? It measures about 4-3/4" in diameter. www.dropbox.com/s/cya3vjofhzzs2nz/Photo%20Sep%2025%2C%207%2057%2056%20PM.jpg?dl=0[/img]
47 Willys CJ2A
52 GMC 1/2 ton
I believe the S-18's shaft is/was too long and will interfere with the steering wheel, thus why the S-16 was used on ADs. It has a shorter shaft. The S-18 was seen more on sedans. At least this was what I learned some time ago on the net.
Craig
Thanks - that's what I'm finding as well. It's only 1.25" longer I think, but I guess that's enough to matter. I've found some parts off a S-16 and I'm going to use that to shorten my shaft on my S-18 if necessary.
47 Willys CJ2A
52 GMC 1/2 ton
