5 members (Uncles51, 55shaker, Woodcmiami, Stovebolt48, joe apple), 65 guests, and 3 robots.
Topics128,021
Posts1,055,351
Members48,420
#1330533 10/20/2019 4:03 PM
Somehow lost the spring on my horn button. The spring that goes around the nut.
Doesn't seem to be a part I can order. Just go to hardware store?
Thanks!
scottss60 #1330550 10/20/2019 7:13 PM
What year/model? Do you have a picture of the spring?
1950 Chevy 3100
scottss60 #1330554 10/20/2019 7:56 PM
Sir Searchalot
Sir Searchalot
Haven't seen them separate, only this.
I'm sure you can find one at hardware store. Nothing special. Just holds the bearing down.
scottss60 #1330559 10/20/2019 8:40 PM
Make sure that you haven't also lost the cone shaped ring on the left in bartamos' linked picture.
scottss60 #1330563 10/20/2019 8:52 PM
Sir Searchalot
Sir Searchalot
I don't know if my link covers the vehicle. Name says 1960 but some posts say 53. I guess it's a closely held secret or we are supposed to have ESPN.
Please advise: ??
1. Amphicar
2. Studebaker
3. John Deere
4. Tucker
5. Isseta 300
6. Yugo
scottss60 #1330575 10/20/2019 11:27 PM
That links shows parts for:
1941-46, 1960-66, 60-63 Chevrolet
and 64-66 GMC
headscratch
tclederman #1330585 10/20/2019 11:47 PM
and 64-66 GMC
headscratch
Seems almost perfectly consistent with a lot of what GM has done over the years. I'm talking about resistance to change for change's sake.
I am more surprised that it does not include '47-'59.
scottss60 #1330588 10/20/2019 11:57 PM
" . . . it does not include '47-'59 . . . "
That is only one of the reasons why I was/am scratching my head.
Jim Carter Truck Parts
different parts shown for:
1931-1940
1941-1946
1947-1959
1960-1968
1969-1972
scottss60 #1330614 10/21/2019 3:18 AM
Sir Searchalot
Sir Searchalot
After thinking in a quiet place in my mind. I finally saw the words "around the nut" in Mr. Scotts post. On some models in some years, including 41-46 and 55-59, there are two springs up in there. One to hold the upper mast bearing in place and another under the horn button and fits "over/around" the steering wheel nut. It's a "return" spring for the button.
Should make scott happy. I would still like to know year/make/model.
Supposition:
Seems like this compression spring went away in favor of the disc/Belleville spring after 1946 and was only used on big bolts. (GMC).
Did not study further. It is also possible that the design changed from up and down button to rocking button, to make contact.
47-60's and up used the disc at the button for light truck.
Most of those years seem to use the mast bearing retention spring.
Shaffer's1950 #1330650 10/21/2019 2:27 PM
53. 1/2 ton. There is a nice diagram in the Chevys of the 40s parts catalog.
scottss60 #1330657 10/21/2019 3:33 PM
Sir Searchalot
Sir Searchalot
Can you advise if one of the two springs we have linked is what you needed? I can't find the Chevs 40's diagram but that's OK if you now see the part and where to get it. If so, this question is answered.
Shaffer's1950 #1330722 10/21/2019 11:09 PM
53 3100 hundred.
