6 members (John L., Otto Skorzeny, Bill Hanlon, Maybellene, 2-Ton, klhansen), 65 guests, and 4 robots.
Topics128,042
Posts1,055,501
Members48,424
#13303 01/23/2004 11:31 PM
I have a 1951 with a 1956 235 intalled by PO. I have had the transmission rebuilt and I am installing a new clutch. The Chevy manual for the 1951 with a 9 1/8" clutch instructs that an "x" on the clutch housing should be lined up with an "x" on the fly wheel. I cannot find an "x" on either part. I did find the "o" for the pressure plate installation and that is set up properly. Does it matter how I align the clutch to the flywheel? Unfortunately I did not mark the clutch housing or flywheel when I removed the clutch. Advise will be greatly appreciated. I get my transmission back Monday and hope to have the job completed that night. :confused:
#13304 01/24/2004 2:03 AM
the clutch should have one face marked as flywheel, that goes toward the flywheel. If you are reusing the old pressure plate you should have marked it to the flywheel. but if the pressure plate is new does not matter as it was ballanced seperate, you will need a clutch plate alignment tool to center to to the flywheel/pressure plate, sometimes a 6 ince piece of bloom handle works too.
#13305 01/24/2004 2:41 PM
That sure sounds easier than looking for an "x" on the fly wheel and clutch housing. Thank you very much. I am using the broom handle method for installation. The job does not appear difficult but I was concerned that there may be a balance problem if I just bolted on the housing. You have put that to rest. Again a big thank you grin
