| | | Forums66 Topics128,037 Posts1,055,576 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2002 Posts: 26 Junior Member | | Junior Member Joined: Jun 2002 Posts: 26 | I'm sure there's been numerous topics on this subject, so my details will be short: we have a '52 deluxe cab 3600 Chevy with a 216 & floor 4-speed. We'd like to go to a crate motor V8. Tranny is still open between manual or auto. I don't suppose anyone's made a "check-list" to follow? I understand everything will have to go: engine, tranny, torque tube, rear axle, 6-volt system. What am I missing? We've updated the front to disk brakes already, and aren't looking at changing the entire suspension unless it has to. Thanks for the help! | | | | | Joined: May 2003 Posts: 328 Shop Shark | | Shop Shark Joined: May 2003 Posts: 328 | I have never done a v8 swap with the stock suspension, but I will tell you a couple of things that I have read here. You will have clearance issues with the steering and the exhaust. If you use the search feature on this board, you will find numerous discussions addressing this topic. You will have to move the steering box, use ram-horn exhaust manifolds with a passenger-side manifold on the drivers side to help clear the steering, and/or you can shift the motor mounts over to the passenger side to help with the clearance issues.
I hope this helps.
Phil
Never hold your farts in. They travel up your spine and into your brain...that is where crappy ideas come from.
| | | | | Joined: Jun 2002 Posts: 26 Junior Member | | Junior Member Joined: Jun 2002 Posts: 26 | Thank Phil. I've not heard anything on that particular subject before - helps a lot. - rick | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I've heard you can use Monte Carlo exhaust manifolds to solve this problem, but I've not tried it.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
