8 members (delwrench, crenwelge, 2-Ton, Cletus1950, Jay R, Hugh63c10, 1955 1 Series, amtrakjoe),
338
Mod | | | Forums66 Topics128,159 Posts1,057,027 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2019 Posts: 14 'Bolter | | 'Bolter Joined: Oct 2019 Posts: 14 | Hello I have a 1955 Chevy 3600 1st series 3/4 ton 4-speed floor shift truck. Do any of you know if the 1/2 ton and 3/4 ton steering gearbox and column are the same for these years? I'm looking for an original gearbox with steering column and want to know if they're compatible. Thank you for your expertise! | | | | | Joined: Oct 2019 Posts: 14 'Bolter | | 'Bolter Joined: Oct 2019 Posts: 14 | Hi George, thanks for that valuable piece of information. I guess I'll give the 1954 1/2 ton gearbox I found a shot. I'll let you know how it turns out thank you. | | | | | Joined: Jul 2007 Posts: 444 Shop Shark | | Shop Shark Joined: Jul 2007 Posts: 444 | I have a GM printed overhaul manual for the steering box.
I copied it on my scanner page by page .
I made it into a very readable pdf.file .
If you'd like a copy give me your email address
and I'll email you a copy .
George '54 3600 | | | | | Joined: Oct 2019 Posts: 14 'Bolter | | 'Bolter Joined: Oct 2019 Posts: 14 | That's awesome George. I would appreciate a copy of that! My email is [email protected] | | |
