| | | Forums66 Topics128,156 Posts1,057,021 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2019 Posts: 14 'Bolter | | 'Bolter Joined: Oct 2019 Posts: 14 | Hello I have a 1955 Chevy 3600 1st series 3/4 ton 4-speed floor shift truck. Do any of you know if the 1/2 ton and 3/4 ton steering gearbox and column are the same for this year? Also can I use a steering gearbox and column from a 1954 truck? I'm looking for an original gearbox with steering column and want to know if they're compatible. Thank you for your expertise! | | |
