1 members (RBs36),
172
Mod | | | Forums66 Topics128,078 Posts1,056,049 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2006 Posts: 70 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 70 | I removed the kick panel vent doors to clean and paint and saw that the seals aren't in very good condition. Classic Parts has new doors, but the pair with tax and shipping would be around $100 so that's out of the question. They also sell the pair of seals for $3.99 in my catalog. I'm concerned cheap seals wouldn't be quality material. Has anybody replaced their seals with catalog parts or find a material that worked out well? | | | | | Joined: Jun 2006 Posts: 70 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 70 | I decided to try a synthetic rubber called Santoprene. It wasn't cheap, a 12" x 12" x 1/8" sheet cost over $20 from Home Depot online. I chose it for it's wide variation of uses in automotive manufacturing. It's supposed to be well suited for seals with long term ageing durability, resistance to extreme temps and flexibility at -60 C.
I dug the old seals out of the original vent doors and cut out the new seals using a paper template. The vent doors are two pieces riveted together and it's necessary to gently pry the outside edges enough to fit the seal between. I think it will work out great. | | |
