| | | Forums66 Topics128,050 Posts1,055,639 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2010 Posts: 66 | I just finished rewiring my 1946 PU and when hooking up the battery with the key in the off position(original Switch with armored cable) the Dash lights come on and I can press the starter and the engine starts to turnover. Can I assume that the this switch is bad and if so what options do I have i.e. where can I get a different ignition switch. thank you | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | It seems to me you have the wires to the light switch hooked up wrong. The starter will turn the engine when you press on the floor starter pedal even when everything else is off. George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Dec 2010 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2010 Posts: 66 | I will check that it seemed that when I wired it all the wires matched up | | |
