Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (Otto Skorzeny, Hotrod Lincoln, frogfarmer), 166 guests, and 3 robots.
Topics128,284
Posts1,058,525
Members48,490
#132920 08/15/2005 3:06 PM
Trying to replace a king pin.... Anyone have any thoughts on a wicked stubborn set bolt?? This sucker doesn't want to budge... hammered it, heated it... nothin'!
Did the other side and that went as smoothly as a king pin job will go but this side seems to be pretty frozen up. In fact, it takes a little effort to turn the spindle by hand (without the steering arm hooked up even!) Now I see why my steering was such an effort!
Larry Bear
55.5 Chevy 3100 Panel
Junior Member
Junior Member
once you have the bolt heated up with the torch, take a block of wax and allow the wax to melt into the threads of the stubborn bolt... than it will tap out like butter. I had to do that on a stubborn drain plug on my posi-differential. no tool would budge the drain plug, but after trying the wax trick the thing spun out by hand.
The wax trick works. I learned that from my machinist friends. That is what it took to get my king pin out. Be careful. The wax will ignite. Use parafin wax.
Bill Schickling
Bill Schickling
1940 1/2 ton, 1940 3/4 ton
My web page
