| | | Forums66 Topics128,165 Posts1,057,087 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2018 Posts: 298 'Bolter | | 'Bolter Joined: Jan 2018 Posts: 298 | I can't seem to figure out how the springs hold the lens in the trim ring. Anyone have a picture or info on how and where they go? Thanks for any help. Bill
1937 GC
| | | | | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | You referring to the "W" shaped springs? I don't think I have a picture of that but the long legs of the spring go toward the bezel & the short, center part rests against the lens. Turn the bezel face down, place the lens in place and position the springs to where the middle part presses against the lip of the lens. Spread the long legs and hook them into the lip of the bezel. They only go one way.
| | | | | Joined: Jan 2018 Posts: 298 'Bolter | | 'Bolter Joined: Jan 2018 Posts: 298 | Thanks Tiny, yes I have 2 installed but the one on the top of the lens also has the metal clip that fits in a slot on headlight bucket. The new set of springs came with 4 springs. No directions so do you use all 4 in one light? Guess I will call supplier and ask unless someone else posts a answer. Thanks again Bill
1937 GC
| | | | | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | I think each lens gets three.
