2 members (Bill Hanlon, JW51),
97
Mod | | | Forums66 Topics128,154 Posts1,056,861 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2010 Posts: 42 'Bolter | | 'Bolter Joined: May 2010 Posts: 42 | Needing new spider gears, side gears, and maybe the cross-shafts for my 1956 3100 differential.
Nothing available on online search. Anyone know where to buy these parts?
Daryl
| | | | | Joined: May 2015 Posts: 11,134 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,134 | Here's one. Not mine. eBayI googled "NOS spider gears for 1956 Chevy Pickup" Apparently eBay has a category for "General Motors Vintage Transmissions & Drivetrains for 1955 Chevrolet Truck" Good luck.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jul 2007 Posts: 444 Shop Shark | | Shop Shark Joined: Jul 2007 Posts: 444 | The pinion gear on ebay is for a 2 - ton truck . Not a half ton . I searched ebay for a 1956 1/2 ton pinion gear & came up with this one https://i.postimg.cc/j2y9kTLW/370225a.jpgGeorge '54 3600
| | | | | Joined: May 2010 Posts: 42 'Bolter | | 'Bolter Joined: May 2010 Posts: 42 | Thanks guys!
I did find these side gears, but the description says they are for overdrive equipped trucks (????), PN 1805308. Didn't know OD trans was used in trucks....
https://www.ebay.com/itm/NOS-GM-1955-1956-Chevrolet-1-2-ton-pickup-axle-gears-with-overdrive-transmission/274019280562?_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D2%26asc%3D20140905073823%26meid%3De151635be4eb41338a95f51a51bd1a11%26pid%3D100284%26rk%3D1%26rkt%3D2%26sd%3D274019280562%26itm%3D274019280562%26pmt%3D0%26noa%3D1%26pg%3D5713&_trksid=p5713.c100284.m3505
Daryl
| | | | | Joined: Mar 2004 Posts: 6,228 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,228 | Thanks guys!
https://www.ebay.com/itm/NOS-GM-1955-1956-Chevrolet-1-2-ton-pickup-axle-gears-with-overdrive-transmission/274019280562?_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D2%26asc%3D20140905073823%26meid%3De151635be4eb41338a95f51a51bd1a11%26pid%3D100284%26rk%3D1%26rkt%3D2%26sd%3D274019280562%26itm%3D274019280562%26pmt%3D0%26noa%3D1%26pg%3D5713&_trksid=p5713.c100284.m3505 This must be a Canadian part number as I can't find it in any of my books. Mike B  | | | | | Joined: May 2010 Posts: 42 'Bolter | | 'Bolter Joined: May 2010 Posts: 42 |
Daryl
