| | | Forums66 Topics128,052 Posts1,055,774 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2011 Posts: 1,362 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,362 | Did GM ever offer them in any of their trucks? I know the power divider / auxiliary 3 speed for the tandems was offered in TF trucks. How about dealer options?
Kicking self for selling off my Taskforce trucks. Still looking for an LCF or conventional big bolt in decent shape.
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | There are a lot of GM trucks with Brownies, hard to believe they weren't offered at least through dealer.
Ed
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Truckrolet, I just went through my 1959 Chevrolet truck sales data book just to be sure, but as I thought no auxiliary transmissions were listed for any of the trucks other than the ones you mentioned in your question, hope that helps. | | | | | Joined: Feb 2011 Posts: 1,362 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,362 | Thank you. And the problem with someone installing something like that its not always done correctly. Just wondering if dealers ever offered such things. The particular truck is supposed to have a 4 speed. When the fellow mentioned a spliter I asked if he meant a 2 speed rear axle, nope its a transmission behind the 4 speed. Just wondering what kind of scabbed up mess it all is.
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Looking in the 1949-53 GMC models 400-980 parts book the index list auxiliary transmission in section 7.5200. That section is really for speedometer adapters but list some of those for use with model 6231 and 8031 auxiliary transmissions.
I don't know what that says for the auxiliary being factory installed or not. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | I have also removed aux. trans like Grigg has, they all looked professionally done, they are listed is service manuals in many GM trucks.
Ed
