8 members (cmayna, baldeagle, Bill Hanlon, Leo, Hotrod Lincoln, Mike in Sycamore, Gdads51, 1955 1 Series), 120 guests, and 1 robot.
Topics128,113
Posts1,056,280
Members48,439
#1327776 09/26/2019 3:13 AM
Bks
Offline
Moderated
Moderated
Thinking about getting this truck guy says it’s a 53 but the dash looks funny what yaw think
Bks #1327795 09/26/2019 10:40 AM
It is not a '53 Chevrolet/GMC truck dash.
Maybe someone will recognize it?
Bks #1327818 09/26/2019 1:10 PM
That's a 1954 - 55 GMC dash. If the title says 1953 or Chevy it's wrong.
Bks #1327971 09/27/2019 11:02 PM
I agree the dash is 54 - 55.1 GMC, but it has the windshield divider bar... ???
Though I have seen some pictures of 54 trucks with divided curved windshields. Don't know if they were non-USA manufactured or what.
Professional Novice
Bks #1328008 09/28/2019 5:27 PM
Well, there's no hole for the clutch pedal either so it must have been a hydramatic truck.
1954 GMC 9314 - 261 t5
canuck49 #1328238 09/30/2019 3:03 PM
I agree. No starter pedal hole either.
The windshield divider bar is still a puzzle...
Professional Novice
Bks #1328256 09/30/2019 4:50 PM
If it is a 54/55 Z-series New Design GMC dash, the holes/cut-outs do not match the original dash - see images.
Also, all 1954/55 GMC trucks had a 1 piece windshield (up to the 450 series).
Bks #1328293 09/30/2019 9:37 PM
If Tim's green dash is a 54/55 dash, it doesn't match the OP's. Too many glove box, radio, ashtray, holes and the choke & light switch holes don't match either...could it be from a really BIG GMC truck???
Need Spanky to get in on this one!
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Bks #1328294 09/30/2019 10:01 PM
The photos I posted above are of the correct dash in a GMC Z-series dash (1954 through early 1955).
I owned and restored a GMC truck with correct dash.
Bks #1328296 09/30/2019 10:38 PM
Thanks Tim, I wasn't doubting you, just observing your picture and the OP's don't match...
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Bks #1328306 09/30/2019 11:48 PM
No problem, Mike
My post was in response to the earlier two posts that said it was 54/55 dash.
I do not know newer dashes, but my guess is late 55 or newer. Not enough info to confirm that it is a “graft” of a dashboard, but that is one possibility?
tclederman #1328312 10/01/2019 12:14 AM
No problem, Mike
I'd say that it is a distinct possibility that it is a one-off grafted dash. There is ample evidence that it has been painted over the original color.
Having said that, GMC did some odd things over the years, but making a separate, very expensive set of dies to make a very short run of panels for that dash isn't very frugal in my opinion.
Carl
Bks #1328313 10/01/2019 12:25 AM
Piping in here, looking at the discussion, and comparing pictures of pre- Z GMC and pre-54 AD dashes, including my ‘54 450,
It really looks like a GMC Z instrument panel grafted onto a , presumably 53 dash!
Frankenstein? If so, ain’t we smart to figure it out!
~Charley
1954 Chevy 3100 with 235
“Bud”
Follow along in the DITY
1963 Chevy half ton stepside short box 230
1954 GMC 3 ton 302
And several more Chevy camper and work trucks 1979 1987 1996
Bks #1328321 10/01/2019 1:50 AM
Crusing in the Passing Lane
My '54 GMC 630 also has a one piece windshield.
Ed
Bks #1328421 10/01/2019 7:23 PM
Dang, Ed. I just got done the other day praising you for always being right, then you go and type "64" instead of "54".
A typo does not make one wrong however, so your "always right" status is still intact. smile
Carl
Bks #1328423 10/01/2019 7:31 PM
I zoomed in on the hole in the dash for the gauge cluster and you can see the remnants of the original dash where it was cut with a cutting torch.
Carl
52Carl #1328433 10/01/2019 9:16 PM
Carl
Good catch.
Definitely looks like a hack job to change out the instrument cluster, but at least the ragged edges will be invisible when the cluster is installed.
