0 members (), 89 guests, and 1 robot.
Topics128,211
Posts1,057,475
Members48,473
Where do I attach the chains from the engine hoist to the engine. A picture would be great.
Elmo
I removed the valve cover and used the two head bolts second from the back and the two head bolts second from the front, It is nice to have a leveler bar too.
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
Thanks SSTOCK,
By the way sweet ride you have there. Nice choice for the color.
Elmo
Thank You Sir
1953 Chevrolet 3100
In the DITY Gallery
1964 GMC 1000
Crusing in the Passing Lane
If it has 2 or 3 valve cover bolts, hook a spreader bar to them, pull only straight on these bolts, also, make sure they are screwed in all the way.
Ed
V
V Offline
I made up a lift bracket out of 1/4" steel plate that attached to the coil mount bolts on the head and wrapped the lift chain around the back runner of the intake manifold using an old piece of inner tube as a cushion between the chain and the manifold. It lifted the engine and transmission together just about perfectly level. I didn't use a leveler as I had removed the front clip but a leveler would make it easier if the clip isn't removed.
I got the idea from a member here.
Pic of brkt
If you peruse youtube theres some video's detailing R&R'ing engines from these AD trucks, good luck.
Dave
