Hy Davie Boy, sixteen inch dual type stud pilot eight bolt tubeless steel wheels should not be too difficult to find, call a few of the wrecking yards around your area and put an ad in the parts wanted forum farther down the page and see what results you get. One of the things people will need to know is the diameter of the center hole required, this is a critical dimension as these are hub piloted wheels. I can't remember that dimension off the top of my head, you will have to measure your hubs and include that dimension in your search information, good luck
