5 members (Oswald, DadsFirstPickup, Hotrod Lincoln, J Lucas, 1955 1 Series), 66 guests, and 1 robot.
Topics128,047
Posts1,055,622
#1327328 09/23/2019 10:33 AM
I have a 1959 261 engine and need to replace the pulley on my alternator with a wider one to match the crank and water pump pulley. Seems to be 5/8 inch wide . Any ideas as to were I might find one of these?
Thanks for any ideas.
Tommy
59 apache 1/2t
261 short stepside
Tommy #1327330 09/23/2019 11:25 AM
AD Addict & Tinkerer
I bought one from Speedway motors.
https://www.speedwaymotors.com/shop/alternator-pulleys~8-2448
Phil
Project Journals
Stovebolt Gallery Forum
Tommy #1327371 09/23/2019 5:12 PM
Any local starter/alternator rebuilder should have what you need.
Tommy #1327406 09/23/2019 8:47 PM
Sir Searchalot
Sir Searchalot
1. Are you saying wider to accept a wider belt? or are you using the word "wider" to mean it does not line up with other pulleys?
2. How wide is the belt?
3. Please tell us what is wrong with the setup now, exactly.
You can't really be sure what pulley until you measure the belt. Measure the ID (bore) and OD of the pulley also.
As mentioned by Carl, I would buy locally. If you are positive about all the dimensions and what alternator you have, you could order online, but risky.
Tommy #1327486 09/24/2019 10:57 AM
Thanks for the responses, The belt is 1/2 inch. The pulley on the alternator is for a 3/8 belt. The pulley on the water pump and the balancer is for 1/2 inch belt.The 1/2 inch belt fills the balancer and water pump pulley and rides high on the alternator pulley.I ordered a pulley from a vendor on here.
Trying to get ready for Cruisin The Coast in two weeks, this will be the tenth year the truck has made the trip.
Thanks all for the suggestions.
Tommy
59 apache 1/2t
261 short stepside
Tommy #1327507 09/24/2019 1:13 PM
One thing to watch on the wider new pulley, is the V groove depth.
My replacement pulley the depth was off enough to cause the belt to bottom out.
I cut the bottom .125” and all was good.
Tommy #1327553 09/24/2019 7:00 PM
Generator and alternator pulleys are a direct swap out but one must use the separate alternator fan and the correct spacers to align and put the right "pinch" on the fan.
Evan
Tommy #1327584 09/24/2019 10:53 PM
Evan,
I thought about that but the pulley and fan on the generator seemed to be spot welded together. I succeeded in destroying the fan so i ordered a pulley that will fit.
Showkey,
I will look at that when the pulley arrives.
Thanks for the info everyone.
Tommy
59 apache 1/2t
261 short stepside
