9 members (Joe H, 3B, baldeagle, Johnny Rib, 68ironhead, 2-Ton, 1955 1 Series, JW51, Guitplayer), 109 guests, and 2 robots.
Topics128,038
Posts1,055,471
Members48,424
I have not driven my '46 Chevy Pickup at night in years until the other night. The headlights are so dim that I thought that I would get into an accident before I got home. I am only getting 4 volts to the lamps and when I turn them on, the gauge goes to the discharge side. This was my Dads project and now it's mine. Years ago I remember adjusting the voltage regulator with him to avoid the lights dimming at idle but I don't remember how to do it.
You guys have helped me before and now I need some more help. How can I get the most out of my 6V Sylvania sealed Beam headlights.I have attached a photo of the Delco Remy regulator.
1946 1/2 ton Chevy Pickup
1954 235 cu in
3 speed on the floor
Crusing in the Passing Lane
Check for a clean, unpainted ground path for a start.
Ed
First, clean up all the connections in the headlight circuit, then check the voltage at the battery posts (NOT the cable clamps) with the engine running at a fast idle. It should be around 7.5 volts against a fully-charged battery. (Charging the battery before doing any adjusting is VERY important). If the voltage is low, turn the Phillips-head adjusting screw on the right hand coil in your picture clockwise a little at a time to raise the voltage. DO NOT mess with the other adjustments. Before doing any adjusting, disconnect a battery cable and scrub a clean piece of business card stock or a slice or a file card between all the points in the regulator.. DO NOT use a file of any kind, or sandpaper on the points.
Be aware that the voltage regulator setting will drop slightly when the regulator cover is reinstalled- - - -steel conducts magnetism better than air does- - - -so set the voltage regulator a tenth of a volt or a little more higher than the final setting you want.
Now, once the charging system is adjusted, try fixing the real problem- - - - it's most likely corroded contacts in the dimmer switch.
Thank you.
Checked the battery voltage -Good
Checked the grounds for the lights - Good.
Checked all connections - Good
Ran a business card through contacts
I only needed to turn the adjustment on the regulator a little less than 1/2 turn and got 6 volts on my analog meter.I think it's all good but I will have to wait until dark to take it for a ride. The color of the light is better now on the wall of my barn.
1954 235 cu in
6 volts
IS
NOT
ENOUGH!
Adjust the charging voltage to 7.5 volts
AGAINST
FULLY
CHARGED
BATTERY!
A fully charged battery will have an open circuit voltage of 6.3 volts with the engine stopped, and/or a specific gravity of the electrolyte of 1.250 or above.
TEST
DON'T
GUESS!
Nice truck... it electrified me!
Another quality post.
Real Trucks Rattle
Shockingly beautiful!
-Kevin
This is what happens when you live with a house-full of women, the wife and daughters name all the cars:
1960 Impala - "Frankie" (Frank Sinatra)
1961 Apache - " 'Mater Jr." (wrecker)
1965 Corvair Monza Convertible
1967 C20 "Ol' Blue" (hidden in a log cabin for 30 years)
1972 SuperBeetle Convertible - "Juliet"
1976 SuperBeetle Convertible - "Olaf"
1988 Alfa Romeo Spider Veloce - "Romeo"
