2 members (Nick in Manitou, 1 invisible), 60 guests, and 1 robot.
Topics128,049
Posts1,055,679
#132652 07/06/2005 2:18 PM
Junior Member
Junior Member
That figures........ I occasionally start the engine of my 46 frown project and run it a while. The other day I went to start it I noticed the coolant level was lower than usual. I looked for leaks, and found coolant leaking at the flex at header collector on left side, leaking out the exaust. I started it anyway and it steemed out the left side exaust. Pulled plugs and one was wet with coolant, oil level was a little high, drained some oil and looks a little milky . All signs are that of a head gasket gone bad. I just can't beleve this could happen. It's been about six years since I put motor in, maybe head gaskets go bad over time. I can't figure why the coolant ran out the exaust. Maybe the head cracked. It's a 305....I'm just frustrated....
"Boop-Boop-a-doop"
#132653 07/07/2005 4:30 AM
It is possible that the head had not been re-torqued, and the bolts relaxed enough to allow the water to seep while the truck was sitting...
just a thought
Garry K
Garry K in Pac Nor West
1948 Chevy PU 235 SM420 4 spd
1932 **** B pu
1964 Datsun 4x4 with SBC, SM465 4spd and Rockwell xfer Dana 44Fr and 12 Bolt Rr.
#132654 07/07/2005 2:24 PM
If this were mine, I'd try re-torquing the heads as Garry mentioned, then changing the oil and use water as coolant for testing. Then I'd see how it works. But it might be a good idea to actually drive the truck, rather than just start it. I've had occasions where I've started vehicles and let them run, only to come back and find out that they had overheated. Luckily, no damage done...but scary.
Btw, head gaskets aren't wear items. They should last for a long time. But if you do have a major problem, now would be a good time to ditch that 305 and go with a nice 350 or 400 smallblock.
(You may have guessed that I'm not much of a 305 fan.)
#132655 07/07/2005 10:47 PM
V
V Offline
i agree try retorqueing first if it doesnt fix it you only out your time if it does you saved a few bucks
#132656 07/13/2005 8:57 AM
if its a305 v8 your intake may be leaking water at the ports
#132657 07/13/2005 11:02 AM
V
V Offline
even if the intake were leaking water at the front cross over it shouldnt get into the cylinders it would likely go into the pan.
