2 members (Materman, 1 invisible), 111 guests, and 3 robots.
Topics128,072
Posts1,055,906
Members48,429
#13256 05/27/2002 12:47 AM
Well, I bought another truck today. It's a small back-windowed '67 LWB. It's got a 1973 V-8 350 with the last of the VIN 13K575542 and S/N TO505CKJ. Anyone have an idea where it came from. I'm thinking it was built in Kansas (K) on May 5th (0505) and is a L65 (CKJ). The 13 is a body code I think. What's a body code 13?
Truck VIN is CS147J154528
Thanks in advance for all the help.
Beat to fit, paint to match
#13257 05/27/2002 1:46 AM
You've 'screw'd the pooch'is what you done! grin
But maybe this will help. smile
VIN CS147J1545280C143K100075
Model Year 1967
Chassis 2 Wheel Drive
Body Style (unknown code)
GVWR Range 3600-5600
Cab-To-Axle Dimension
Engine 6-Cylinder
Assembly Plant Janesville, WI
Sequential Number 1545280C143K100075
Transmissions
Code Series Description Plant
N N/A 4 Speed Muncie
P N/A 4 Speed Muncie
W N/A 3, 4 Speed Warner Gear
R N/A 4 Speed Saginaw
K N/A 3 Speed McKinnon
S N/A 3 Speed Saginaw
M N/A 3 Speed OD Muncie
O N/A 3 Speed OD Saginaw
D N/A 3 Speed OD Saginaw
C N/A Powerglide Cleveland
E N/A Powerglide McKinnon
T N/A Powerglide Toledo
CA N/A 3 Speed Auto Hydramatic
1967 Factory Color Codes
Code Description
500 Black
503 Light Green
505 Dark Green
506 Medium Blue
507 Light Blue
508 Dark Blue
511 Dark Aqua
514 Red
515 Vermillion
516 Orange
519 Yellow
520 Light Yellow
521 White
523 Silver
526 Ivory
#13258 05/27/2002 1:49 AM
#13259 05/27/2002 3:40 AM
O.K. - That's the part I knew, I'm still wondering what a 1973 GM Body Style 13 is. Is it a Camaro, Biscayne, Chevelle, Caprice, El Camino, Nova...it's something that came with a 350 L65 motor...not that this really keeps me from enjoying my new-found toy...it just makes me wonder and this is the best place I know for answers to this kind of question. If I had the preceding 3 digits in the VIN, I'd be done. The first is a C, the second two are a mystery.
Would a casting number from the intake help? P/N 16436572....oh yeah, kicks, the body style is Fleetside 127" WB and the Protect-a-Plate RPO indicates 3 Speed Auto Hydramatic and the data plate is stamped 5000 GVWR. You're right on about the 6 cyl (S)...and Janesville (J), too. She was a lovely shade of 520 (Lt. Yellow) with Deluxe Heat, Heavy Duty Suspension, Power Steering and Brakes, Full Gauges including Clock (no vacuum or tach frown )and an AM Radio. It's all still there and in working order, less the clock. She's a lot further along than the '66, which I'm giving to my uncle to restore.
Ain't research grand...now if only the money were this easy to find.
Thanks for the info and to all for the example of how to do it all the way and right.
#13260 05/27/2002 6:02 AM
That number on the intake manifold is the firing order:1,8,4,3,6,5,7,2!!!! grin
#13261 05/28/2002 4:28 PM
Quote
Originally posted by C1534:
O.K. -
Thats one of them rare 7 cyl. engines. grin
Kidding.
Maybe this may help you?
http://www.nastyz28.com/decode.html
