6 members (Ponchogl, 48ed56pam, Bill Marlow, Hanks custodian, frogfarmer, 2-Ton), 246 guests, and 0 robots.
Topics128,081
Posts1,056,071
Members48,434
#1325811 09/11/2019 9:52 PM
Hello Everyone,
So I purchased this 1954 Panel Truck about a year ago. It’s not been on my project list until just this past week. So I removed the front clip in order to replace the engine. That all went well... removed the engine with no troubles. During the clean up I discovered a major crack in the frame right by the leaf spring bracket. I’ll add a picture.
So my question is how hard is it and how do I remove the body?
Thank you.
Scott
[img]https://www.stovebolt.com/ubbthread...BD4EE78-134D-4562-9950-AA0D63ADFF00.jpeg[/img]
Chevytruckdaddy
looks like a failed repair.
Sir Searchalot
Sir Searchalot
Very bad repair. Looks like spring hanger is even welded. One idea is to replace frame. The fix is a good size job.
Thank you for your reply, I have a replacement 54 frame so I’m just going to do a swap. What do I need to do to remove the body from the broken frame? I know I’ll need to remove the steering column and the gas tank filler neck. I have a fork lift so picking up the body will be easy.
How many mounting bolts are there? Anything else I need to be looking at?
Thank you
Scott
Chevytruckdaddy
Sir Searchalot
Sir Searchalot
Probably about 10 bolts. You will just have to examine. You also have your pedals, wiring, gas lines to tank, transmission shifter, speedo cable, battery cables, body to frame ground strap....
The ideal method is to lift body, roll out chassis, roll in a wooden wheeled body dolly and set body down. Roll chassis to work area. Move body aside on dolly.
All those carriage bolt heads you see on your floor? Those are your body mount bolts. It's been a while but, two in the footwell, two behind the seat, two mid-floor and two at the rear. I might be missing a pair.
Yup, I missed a pair. Two in front of the rear wheel well, two behind the rear wheel well and two on the rear deck. Plus the already mentioned front floor and behind the seat.
Awesome, yes I’ve removed all then wiring and pedal. 10 bolts sounds as easy as removing the front clip. That only tool me 45 minutes to remove.
[img][/img]
Chevytruckdaddy
Sir Searchalot
Sir Searchalot
I've been adding to the removal list. I think you have it all covered. Good luck.
I wouldn't attempt to repair a frame that far gone. I'll bet you find other stuff that's "not optimal" as well. Good that you have a spare frame to swap out.
Bartamos, that "wing" thing behind that POS repair is the front body mount bracket.
Scott, sorry I don't know how many mounting bolts on a panel, but one of the guys can probably answer that question. You'll need to pull the steering wheel, unbolt the steering column from the frame, and remove the brake and clutch pedals (they bolt to their lower arms in front of the firewall. Also, misc engine controls (throttle pedal linkage, parking brake linkage, etc.) will need to be removed. You could lift the body off without removing the steering column, but you'd have to move the frame forward as you lift to clear it.
on edit: I see the engine is already removed, which will make things easier.
Ok nice I’ll cut those bolts tomorrow and make a rolling cart to support the body. I’ll add photos tomorrow evening.
Thank you
Scott
Chevytruckdaddy
No I agree with you, removing the steering column is an easy task pulse I’ll need it for the new frame swap.
Chevytruckdaddy
Easy dolly.
Very nice, Mark
Something to consider: if you stacked two more rows of 6x6s, you might be able to paint the whole body on that assembly?
The extra height would get it up enough to reach the entire curved bottom-edges?
That is what we did with my ‘54 Suburban.
That was back in 2006. Paint wasn't a consideration back then. Just frame work. It would make life easier if I still had it on the dolly!!
I removed my panel body. There were 10 bolts. I used travel trailer tipout screw jacks on all four corners to raise it.
You said you had a replacement '54 frame; Is it a panel or Suburban frame? Pickup frames are missing the panel truck body mounts. They can be fabricated fairly easily however, or you can transfer them over from your cracked frame.
1951 Chevy Panel Truck
Sir Searchalot
Sir Searchalot
Hey Mark, you don't sound like Darth anymore
grin grin chug
Sir Searchalot
Sir Searchalot
I thought you would want to change the Avatar text to match your new pic?
I'll leave it just so everyone will be left feeling how I feel every morning when I wake up. Dazed and confused.
