5 members (Phak1, Gdads51, TUTS 59, DaveV, 3B), 83 guests, and 2 robots.
Topics128,056
Posts1,055,789
#1325282 09/07/2019 10:59 PM
So I couldn't bolt the heads onto my freshly machined 265 today. The head bolts only have 2 lengths instead of the typical 3 different lengths like later heads. I have searched in vain this afternoon including manufacturers websites, forums and anywhere else Google led me. Any ideas on where to get the correct stuff? Thanks
Don't pay no mind to that whirrin' sound, she uses a little oil but outsida' that she's cherry.
Redline #1325286 09/07/2019 11:40 PM
Are the long head bolts for the later model engines the correct length? If so you only need to buy 4 bolts to complete the set. Dorman head bolts used to be available for individual purchase. If you can't find them that way, one option would be to purchase a second set of head bolts and use enough of the ones that are the correct length to complete the job. Head bolts don't know, or care what size engine they're in, as long as the length, thread engagement, and torque is correct.
Using studs the right length with nuts and hardened steel flat washers from ARP would be another, but much more expensive option.
They seem to be a bit long but I didn't try to torque anything down.
Redline #1325293 09/08/2019 12:23 AM
Use a 7/16" diameter Grade 8 hardened steel SAE flat washer under the bolt head if the bolts thread too deep into the block. They're available on Ebay in several different thicknesses and quantities- - - -very low cost and very useful in a lot of applications. I've built a lot of small block round track race engines with them. I was using them to adjust the thread engagement on head bolts used with heads that had been angle-milled for changing the compression ratio.
Redline #1325349 09/08/2019 8:40 PM
' Offline
Jeg's sells a set of 265 Chevy head bolts
made by Mahle - Mahle # GS33285
LINK
https://www.jegs.com/i/Clevite/695/...6ODc2OnrZ5kzCKJlU1WjGzO2vWBoCgz4QAvD_BwE
George
'54 3600
1954 3600
Now cruising in
The Passing Lane
Redline #1325357 09/08/2019 9:12 PM
Nope- - - -that's for the late model 265, not the mid-1950's engine. That set has two intermediate-length bolts that aren't used on the 50's heads.
' Offline
In my 1958 parts manual it says ,
V-8 (exc.348) , Head Bolts
1955 to 1958 , so that would cover the 265 V-8
SHORT BOLT - 7/16 ' - 14 X 1 & 3/4 "
GM # 0.293 - GM # 3704796
Dan's GM Obsolete
Chinook , Montana
phone : 406 - 357 - 2615
Dan's probably has some in stock .
LONG BOLT - 7/16 " - 14 X 3 & 3/4 "
GM # 0.293 - GM # 3741278
Craig Motors
Napa , CA.
phone : 800 - 224 - 8111
Craig Motors probably has some in stock
I think these are going to be hard to find NOS .
George
'54 3600
1954 3600
Now cruising in
The Passing Lane
Redline #1325681 09/10/2019 11:22 PM
Thanks for the help so far, still looking.
Edit. One of the Corvette parts houses has them, Just ordered a set.
