| | | Forums66 Topics128,052 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 23 'Bolter | | 'Bolter Joined: Apr 2010 Posts: 23 | So I couldn't bolt the heads onto my freshly machined 265 today. The head bolts only have 2 lengths instead of the typical 3 different lengths like later heads. I have searched in vain this afternoon including manufacturers websites, forums and anywhere else Google led me. Any ideas on where to get the correct stuff? Thanks
Don't pay no mind to that whirrin' sound, she uses a little oil but outsida' that she's cherry.
| | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | Are the long head bolts for the later model engines the correct length? If so you only need to buy 4 bolts to complete the set. Dorman head bolts used to be available for individual purchase. If you can't find them that way, one option would be to purchase a second set of head bolts and use enough of the ones that are the correct length to complete the job. Head bolts don't know, or care what size engine they're in, as long as the length, thread engagement, and torque is correct.
Using studs the right length with nuts and hardened steel flat washers from ARP would be another, but much more expensive option. Jerry
| | | | | Joined: Apr 2010 Posts: 23 'Bolter | | 'Bolter Joined: Apr 2010 Posts: 23 | They seem to be a bit long but I didn't try to torque anything down. Are the long head bolts for the later model engines the correct length? If so you only need to buy 4 bolts to complete the set. Dorman head bolts used to be available for individual purchase. If you can't find them that way, one option would be to purchase a second set of head bolts and use enough of the ones that are the correct length to complete the job. Head bolts don't know, or care what size engine they're in, as long as the length, thread engagement, and torque is correct.
| | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | Use a 7/16" diameter Grade 8 hardened steel SAE flat washer under the bolt head if the bolts thread too deep into the block. They're available on Ebay in several different thicknesses and quantities- - - -very low cost and very useful in a lot of applications. I've built a lot of small block round track race engines with them. I was using them to adjust the thread engagement on head bolts used with heads that had been angle-milled for changing the compression ratio. Jerry
| | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | Nope- - - -that's for the late model 265, not the mid-1950's engine. That set has two intermediate-length bolts that aren't used on the 50's heads. Jerry
| | | | | Joined: Jul 2007 Posts: 444 Shop Shark | | Shop Shark Joined: Jul 2007 Posts: 444 | In my 1958 parts manual it says ,
V-8 (exc.348) , Head Bolts
1955 to 1958 , so that would cover the 265 V-8
SHORT BOLT - 7/16 ' - 14 X 1 & 3/4 "
GM # 0.293 - GM # 3704796
Dan's GM Obsolete Chinook , Montana phone : 406 - 357 - 2615
Dan's probably has some in stock .
LONG BOLT - 7/16 " - 14 X 3 & 3/4 "
GM # 0.293 - GM # 3741278
Craig Motors Napa , CA. phone : 800 - 224 - 8111
Craig Motors probably has some in stock
I think these are going to be hard to find NOS .
George '54 3600
| | | | | Joined: Apr 2010 Posts: 23 'Bolter | | 'Bolter Joined: Apr 2010 Posts: 23 | Thanks for the help so far, still looking.
Edit. One of the Corvette parts houses has them, Just ordered a set.
