BUSY BOLTERS Are you one? The Shop Area
| | Click on image for the lowdown.
| | Forums66 Topics126,776 Posts1,039,271 Members48,100 | Most Online2,175 Jul 21st, 2025 | | | Joined: May 2005 Posts: 5 Junior Member | Junior Member Joined: May 2005 Posts: 5 | I HAVE A 55 CHEVY TRUCK 2ND SERIES AND AN OLD CHRYSLER WITH A 440 IN IT HOW HARD WOULD IT BE TO PUT IT IN MY TRUCK? | | | | Joined: May 2005 Posts: 50 Wrench Fetcher | Wrench Fetcher Joined: May 2005 Posts: 50 | Why on God's green earth would you want to ruin a great Chevy truck with a 440? Sell it and buy a Chevrolet motor. Truthfully the 440 is probably worth more than a Chevrolet small block, but I'm thinkin big block. Sell it and put a 454 in it, you'll be lots happier .
Dave
Even a blind squirrel gets a nut sometimes!
| | | | Joined: May 2001 Posts: 7,440 Extreme Gabster | Extreme Gabster Joined: May 2001 Posts: 7,440 | Wouldn't be hard at all if you have all the tools you need and the experience at this kind of job. Go for it. | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | A lot of work!
If you consider the negative impact on resale value, its going to be cheaper to give away the 440 and buy a Chevy motor to put in the truck.
A Chevy small block was available in your truck, so putting one in can be done with stock parts, and it looks like it belongs.
The resale market will accept a Chevy V-8 in almost anything, and will pay a premium for a hemi if done right. But an old wedge isn't a real popular motor these days, and will reduce the value of of most any non-Chrysler you'd put it in.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | Shop Shark Joined: Aug 2004 Posts: 1,067 | How about a 400 based Chevy small block? Lots of torque in a small package that would be a lot more compatible for your truck.
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | | | Anonymous Unregistered | Anonymous Unregistered | You can probably make it work but you may have to fabricate new motor mounts and a transmission cross member. As most others are saying this is not a common substitute but anything is possible with the right determination and ability. If you have all the pieces that go with the 440 such as the transmission, exhaust manifolds then you should be okay. That engine bay is huge but before you start you may want to do some measuring to ensure you have enough front to back clearance. Take pictures. | | | | Joined: Apr 2005 Posts: 28 Junior Member | Junior Member Joined: Apr 2005 Posts: 28 | It's very easy to put it in. Hooking it up is the hard part.
Seriously- go for it. Do something different. I'd buy a Chevy truck with a 440 in it. You might want to look at some of the Mopar musclecar sites and suppliers. There are several kits out there to swap 440's into A-bodies (i.e. Darts)- you might be able to use parts from those to get the frame-side motor mounts, if you're not into fabrication. Use the Mopar Performance electronic ignition conversion for spark control- beats the hell out of points or trying to adapt to the Chevy system. | | | | Joined: May 2005 Posts: 50 Wrench Fetcher | Wrench Fetcher Joined: May 2005 Posts: 50 | MOPAR MUSCLE is an oxymoron. Seriously I would drive a Dodge way before I'd ever consider buying some foreign P.O.S.
Dave
| | | | Joined: Dec 2003 Posts: 510 Shop Shark | Shop Shark Joined: Dec 2003 Posts: 510 | As others have said, it would be one heck of a lotta work. Nothing's impossible....some things just take more time, money and effort...not to mention ingenuity. However, if it was me, I'd stay with the Bowties. A .030 over 400 smallblock gives you 406 CID (.040 over...the safe maximum for a 400) is roughly 409. It'd be kool to say that you have a 409-powered truck. I may do this when I rebuild the 400 in my El Camino. Then there's the big blocks. 396, 454...a little boring and 468 or 472...A lotta latitude that way. If you wanted to go nuts, you could get a 502 CID crate motor from GM. I know a guy who runs one in a 41 (or so) Diamond T. It's a very kool truck. I've considered putting a 392 or 426 Hemi into my 63 Nova, (it has a 355 and 4-speed at the moment) just to be different...but I don't think it'll ever get past the "thinkin about it" stage. Good luck with it, | | | | Joined: Feb 2005 Posts: 355 Member | Member Joined: Feb 2005 Posts: 355 | JFK, Do what makes you happy and what you can afford, unless you are planning to sell (for profit) or show the truck. Houston54 was right, you will most likely have to fabricate new motor mounts and a tranny cross member. We did, and we only put a 305 in our '54. It just takes time, patience, and good planning. Neither was expensive or even that difficult.
One word of advice: think about potential areas you are going to have interference with your fabricated mounts and accessing parts. For example, our "new" motor mount is making it pretty d*mn hard to replace the fuel pump! Also (this was an issue with both of our Stovebolts) make sure you've got sufficient firewall clearance for your distributor – I'm not familiar with the 440, but you might have some clearance issues there too.
Have fun with it. K | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | Shop Shark Joined: Dec 2003 Posts: 1,554 | Theres a guy up towards Cleveland who has an older Ford pickup with a 426 hemi in it.Man does that truck get a lot of attention.So putting a 440 in your Chevy would be unusual,but to me thats what these old vehicles are all about.Go for it. | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | Shop Shark Joined: Aug 2004 Posts: 1,067 | Tell you what, if I got my hands on a V10 Dodge engine for a killer deal, I'd adapt it to work in my truck!!!
Actually, another good idea which is very feasible (unlike the V10 idea) would be a Buick, Olds, or Pontiac 455. It doesn't take much to get 600 lb-ft on pump gas out of those engines. Great truck engines...too bad they never put them in trucks.
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Originally posted by Hot Rod Dad: Buick, Olds, or Pontiac 455. ..too bad they never put them in trucks. The 455 Olds seems to be a popular replacement in 80's trucks that came with that unsuccessful Olds diesel. My brother used to own a '62 Chevy pickup with a 455 Buick in it. It was one very strong truck.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | Joined: Jun 2004 Posts: 39 Wrench Fetcher | Wrench Fetcher Joined: Jun 2004 Posts: 39 | Thats it keep listing to the chevy boys,and let me know and I will trade you a small block for that junk mopar 440!
48GMC 5window,350,700R4,p/w,p/b,and a couple of homemade parts! 41 Sedan Delivery next up to be reborn!!
"Nothing is Junk,just unfinished projects" Desert rat with a spray gun!
| | | | Joined: Jun 2005 Posts: 8 Member | Member Joined: Jun 2005 Posts: 8 | Originally posted by Kimberly McDowall: JFK, Do what makes you happy and what you can afford, unless you are planning to sell (for profit) or show the truck. Houston54 was right, you will most likely have to fabricate new motor mounts and a tranny cross member. We did, and we only put a 305 in our '54. It just takes time, patience, and good planning. Neither was expensive or even that difficult.
Have fun with it. K
build it to last,drive it like you stole it,enjoy life
| | | | Joined: Jun 2005 Posts: 8 Member | Member Joined: Jun 2005 Posts: 8 | 440 distributor is in the front of the engine
| | | | Joined: Apr 2005 Posts: 641 Shop Shark | Shop Shark Joined: Apr 2005 Posts: 641 | seen it done had a steel tilt front end to said it was fast you better have power steering he weacked it to much beer | | | | Joined: Jan 2004 Posts: 112 'Bolter | 'Bolter Joined: Jan 2004 Posts: 112 | Speed costs money......how fast do you want to go? Repeat...
| | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | Shop Shark Joined: Aug 2004 Posts: 1,067 | As fast as you can afford to go...
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | | | Joined: Feb 2005 Posts: 60 Member | Member Joined: Feb 2005 Posts: 60 | Caddy motor is also a good choice but if you have the 440 why not? Its just a motor it dont know any better. I think i would be thinking about a IFS. That 440 is going too be pretty darn quick. Think i would pass on a viper motor they just plain sound crappy. Cool looking but something is wrong with the exh note it sounds like a big import. | | | | Joined: Sep 2004 Posts: 148 Member | Member Joined: Sep 2004 Posts: 148 | Originally posted by DJ: Caddy motor is also a good choice but if you have the 440 why not? Its just a motor it dont know any better. I think i would be thinking about a IFS. That 440 is going too be pretty darn quick. Think i would pass on a viper motor they just plain sound crappy. Cool looking but something is wrong with the exh note it sounds like a big import. i think they sound funy because two cylinders fire at once, so it sounds like a 5 cylinder motor
2003 ford lightning 1959 chevy 36
| | | | Joined: Jun 2005 Posts: 221 Wrench Fetcher | Wrench Fetcher Joined: Jun 2005 Posts: 221 | Depending on year and what kind of chrysler you can probably sell the 440 to some Mopar fanatic for enough to build a good small block.if it is in an Imperial these were what chrysler called Premium engines they were hand assemled from hand fitted parts.most die hard mopar fans would trade their fist born kid for one in good shape | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | Shop Shark Joined: Aug 2004 Posts: 1,067 | You're right there. Mopars are going for crazy money right now. I should have bought that '70 Challenger when I had the chance back in college!!! Now I'd have to sell my left nut to own one.
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | | | Joined: Sep 2004 Posts: 120 Member | Member Joined: Sep 2004 Posts: 120 | ya you should put a small block chevy in it and be like every other truck out ther, or you could put the 440 in and when you get alot more money you will already be redy for that hemi you will get that will fit right in | | | | Joined: Apr 2005 Posts: 926 Shop Shark | Shop Shark Joined: Apr 2005 Posts: 926 | I was given a '61 F-100 panel with a 440/727 once;it was pretty neat,and the builder said it wasn't as hard as he thought it'd be to install. The old man who owned the speed shop I used to hang around once told me when I asked about putting a caddy 500 in a Jeep wagoneer,"Son,I can make anything fit anything-all it takes is money." | | | | Joined: Sep 2004 Posts: 148 Member | Member Joined: Sep 2004 Posts: 148 | i heard something similar once at a body shop. the owner was talking to a guy who owned a hot rod shop and a salvage yard (nice combo!). he said you can make anything fit with a torch and a welder.
| | | | Anonymous Unregistered | Anonymous Unregistered | You also need a BFH for those close tolerance issues involving fragile items. | | | | Joined: Sep 2004 Posts: 148 Member | Member Joined: Sep 2004 Posts: 148 | or the mini-bfh for use in tight spaces
| | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | Shop Shark Joined: Aug 2004 Posts: 1,067 | At the car show I went to this weekend, there was one Chevy 1/2 ton truck that had an Olds 455 in it. He dynoed it at 600 lb-ft at only 1800 rpm! That's with just a carb on top. I wouldn't get that much torque with even a roots supercharger on top of my 406.
Something to think about.
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | | | Joined: Apr 2005 Posts: 926 Shop Shark | Shop Shark Joined: Apr 2005 Posts: 926 | The Buick,Olds,Pontiac 455's made over 500 ft/lbs of torque stone stock. The Cadillac 472 and 500 engines made slightly more,but all of 'em are naturals for trucks.(The Caddy would need the end of the crank drilled for a pilot bushing if you want to use a manual transmission in it.) Speed | | | | Joined: Apr 2005 Posts: 151 Member | Member Joined: Apr 2005 Posts: 151 | Friend stuffed one in an old Land-Rover so it shouldn't be hard to put one in yer truck.
Different is good! Mopar in a Chevy? Blowhard purists will see it as a mortal sin. They'll foam at the mouth and cover their children's eyes and pray for your soul when you pop the hood. Cool. Do it!
Christian | | | | Joined: Nov 1995 Posts: 5,470 Bond Villain | Bond Villain Joined: Nov 1995 Posts: 5,470 | We were having this conversation at the dinner table just last night -- I'm with Christian and Kimberly. I've heard all the pro's regarding SBC's in AD trucks and they're pretty convincing. But, after you've seen the umteen bazillionth truck with a 350/TH350 combo in it, you fail to "Oooh and Ahhh" appropriately, I guess. A 440 would solve that malaise nicely. A V10 would be cool, too (As HotRodDad said. "Hard" is a relative and very subjective term, as you can tell from the discussion. But as they say above, it all boils down to how much "B" ya got in your BFH, and how many rounds ya got for your "Dollar Gun." I say go for it, too. What the heck. Don't forget the Cross Ram Induction!!!! MOPARS ROCK!!! ClosetMOPARBoy, er, I mean JOHN. Yeah, John!
~ John "We are not now that strength which in old days Moved earth and heaven; that which we are, we are" 1948 International Farmall Super A1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump2001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | Joined: Mar 2005 Posts: 171 Shop Shark | Shop Shark Joined: Mar 2005 Posts: 171 | good for you john! i happen to be a diehard chevy man, but i'll never put a smallblock in anything i build. an SBC is the cheapest & easiest power any one will ever get. it's understandable why it's so popular. but quite frankly it's boring! when i go to a show or event anymore i seldom look under the hood because i know what i'll see..... an SBC! what's really sad, especially knowing chrysler produced such fine engines is seeing a mopar street rod or classic truck with a SBC. so, JFK stick that 440 in that truck! robert. | | | | Joined: Apr 2005 Posts: 151 Member | Member Joined: Apr 2005 Posts: 151 | Best motor I ever had was a built Mopar 360. If I still had it, it'd be in my 54 right now. | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I still think its a crazy idea, but more important is to note that the guy who asked the question hasn't come back to this thread and hasn't posted at all in three weeks.
One suspects he asked just to stir up trouble...
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | Joined: Mar 2005 Posts: 5 Junior Member | Junior Member Joined: Mar 2005 Posts: 5 | I am already puttin the 8.75 out of my racecar in my 51,and I am thinking real hard about putting the 360 out of it in there also. Cheaper than a 350 cuz I already have it. | | |
