| | | Forums66 Topics128,030 Posts1,055,423 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2000 Posts: 98 'Bolter | | 'Bolter Joined: Oct 2000 Posts: 98 | I'm trying to add an electric choke on my 1966 Chevy c-10. The original fuse block is full because of other things I have added in the past. I'm trying to figure out how to get power to the choke with out space on the fuse panel. I'm giving some thought to adding a small fuse block for this. How have some of you overcome this type of situation? Help appreciated.
Mike Kelley 1966 Chevy C10 SWB - 250 L6/S10 T5 2002 Chevy Ext 1500 4x4
Http://myol66.wordpress.com
| | | | | Joined: Aug 2012 Posts: 1,214 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 1,214 | You'll want to wire it through your ign switch (or relay) so it's only hot with the key "on". You can wire in an in-line fuse for circuit protection. | | | | | Joined: Oct 2018 Posts: 112 Shop Shark | | Shop Shark Joined: Oct 2018 Posts: 112 | Pull a wire from the ignition wire on the starter to the choke, and simply run an in-line fuse for it. Probably a 20 amp fuse should get it.
Chris
'64 Chev C20 LWB stepside (Ol'Blue)
