1 members (Ridgeback), 42 guests, and 2 robots.
Topics128,035
Posts1,055,443
Members48,422
#1324535 09/02/2019 9:56 PM
I'm trying to add an electric choke on my 1966 Chevy c-10. The original fuse block is full because of other things I have added in the past. I'm trying to figure out how to get power to the choke with out space on the fuse panel. I'm giving some thought to adding a small fuse block for this. How have some of you overcome this type of situation? Help appreciated.
Mike Kelley
1966 Chevy C10 SWB - 250 L6/S10 T5
2002 Chevy Ext 1500 4x4
Http://myol66.wordpress.com
Mike K #1324552 09/02/2019 11:33 PM
V
V Offline
You'll want to wire it through your ign switch (or relay) so it's only hot with the key "on". You can wire in an in-line fuse for circuit protection.
Mike K #1324628 09/03/2019 6:07 AM
Pull a wire from the ignition wire on the starter to the choke, and simply run an in-line fuse for it. Probably a 20 amp fuse should get it.
Chris
'64 Chev C20 LWB stepside (Ol'Blue)
