| | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#13245 01/29/2003 11:24 PM | Joined: Jan 2002 Posts: 12 Member | | Member Joined: Jan 2002 Posts: 12 | In a 58,when changing from 6 cyl to 8cyl do you use the same 2 front holes in the crossmember? Can i use these holes for a reference. Also there are holes on the top of the frame rails above the brake lines.Are these for mounting side motor mounts? I would like to change to side mounts.
john j
