4 members (Bill Hanlon, Hotrod Lincoln, crenwelge, 78buckshot), 73 guests, and 0 robots.
Topics128,080
Posts1,055,951
Members48,430
#132387 04/13/2005 3:54 AM
Junior Member
Junior Member
I purchased an offenhauser dual intake and was wondering on how to hook up the linkage. If i have to choke both carbs, how to run the fuel and vacuum advance lines and any other information you may have.
#132388 04/13/2005 7:16 AM
FWIW: On my 235, I have an Offy dual intake. I purchased 2 Carter Weber carbs and the linkage from Stovebolt Engine company. Th1s carb has an electric choke. I only hooked up one. Likewise with vacuum. Stovebolt will supply instructions with these items.
#132389 04/13/2005 11:35 AM
I installed Offy with Rochesters last fall. The Rochesters were remanufactured by Holly. I don't recall where I bought them but they never did pump fuel. I pulled those and installed Carter Webers this past weekend. The instructions on the linkage setup from Stovebolt left a lot to be desired. One little picture from one angle was not enough. I figured it out though. The carbs are mounted and the linkage is functioning.
I haven't plumbed the fuel or vacuum yet. One thing I learned from my Rochester install that I'll pass along. Don't even try to use compression fittings. I couldn't get those fittings tight enough to stop the leaks. And; they were easy to over-tighten and break.
I can't wait to see how those carbs run. I was very frustrated with my truck all winter because I wasn't able to enjoy it after I started the conversion to 2 carbs. I'm starting to get excited again. Now; if I could ever get some time at home to finish the job...
Jerry Acheson
Indianapolis, IN
57 Chevy 3100
