| | | Forums66 Topics128,072 Posts1,055,903 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2019 Posts: 119 'Bolter | | 'Bolter Joined: Mar 2019 Posts: 119 | I found a few posts regarding the panel that attaches to the rear of the AD seat back. It hides the springs from view when you look through the back window. We are working on a '49 3100.
Can anyone provide a picture of exactly how this panel is installed? I know there are 6 spring type pins that attach the lower edge of the panel to the vertical strips on the seat back. We do have those pins and I see the holes where they connect to the seat frame.
I am trying to determine how the upper edge is retained so it is tight against the seat frame.
Thanks for the help.
Rusty
| | | | | Joined: Sep 2013 Posts: 1,362 'Bolter | | 'Bolter Joined: Sep 2013 Posts: 1,362 | Check out my post and images here from 3 years ago. Back them posting images directly to threads wasn't an option on the 'Bolt and I wasn't using a hosting site (still not) so never put em up here. Good Luck, RonR
RonR
1951 3600 with Clark flatbed, T5, 4.10 rear 1970 340 Duster 1990 5.0 V8 Miata (1990 Mustang Gt Drivetrain) 1964 CJ5
| | | | | Joined: Mar 2019 Posts: 119 'Bolter | | 'Bolter Joined: Mar 2019 Posts: 119 | Hi RonR,
Thank you very much! 2 of those pictures show me exactly what I need to know.
I had to chuckle when I saw the NA Miata in the background. You would see a similar car in the background of my shop pictures, except it is a '95.
Rusty
