3 members (tclederman, UtahYork, 1 invisible), 105 guests, and 2 robots.
Topics128,031
Posts1,055,433
Members48,422
#1323512 08/26/2019 12:54 AM
I found a truck ive been watching on CL. I didn't call yet. I dont call unless im ready to pull da trigger. Dont like to waste the sellers time being a time waster. Anyhow. The application is a 1959 GMC 100. I know is has a 3 on the tree and a 6 cylinder is listed. My question is what 6 cylinder is stock for that truck?
Probably a 270?
What is the code pressed into the block at the rear of the distributor?
I have no idea. But will check if I move forward. Any other possibilities? Or just a 270
All GMC engines look similar- - - -228, 248, 270, and 302. There's also a 256, but they're extremely rare- - - -mostly Canadian military engines for that one. The only real way to tell the difference is to look at the stamped number by the distributor, or measure the bore and stroke.
Good to know. Thanks for the info.
Moderator
Moderator
2 Offline
Jerry, When did the 292 six come out?
That's what's in Vicki's 65 one ton.
Don
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
I believe it showed up in the early 1960's- - - -63 or 64, maybe? It was an upsized version of the 194/230/250 engines that shared a lot of design features like the bellhousing bolt pattern and a few internal parts with small block V8's. The first of that generation of engines came out as a 194 in the 1962 Chevy II, along with a similar-design 4 cylinder. The 292 is a raised-block version of the 250 with a much longer stroke, a taller side cover, and an offset motor mount on one side of the block.
The 228 through 302 GMC's use the same bellhousing and a few other parts as the 216, 235 and 261 Chevy engines.
Moderator
Moderator
2 Offline
Jerry, You really amaze me on your knowledge!
You answered that question in < ten minutes!
I know you didn't have time to look it up!
Don
"The Flag Pole"
1953 1-ton pickup
Moderator
Moderator
2 Offline
"The Flag Pole"
1953 1-ton pickup
awesome, and thanks again.
Crusing in the Passing Lane
The later series engines are about 3 inches longer than earlier Chevy engines, about the same length as GMC 6's.
Ed
1963 was the first year for the 292 in Chevrolet big trucks...
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
U snooze, U lose.. I guess we will never know. Its sold....grrrr
0
0 Offline
Gotta be quick on the draw with 'old iron'..... Roll the dice & worry about it later.......like i just did !!!
IKR. Lesson well taught again... The next one wont get away.. HA
Firstly, do not trust wikipedia. smile
Secondly, Jerry's correct (as usual). wink In all my original GM text, the 292 was first offered in 1963, weighing in at 165 hp @3800 and 262 ft-lbs @ 2000. Also that year, the 145, the 153, High Torque 230, 283, 327, 348, and 409. In the Diesel category, the 4-53, and 6V-53.
All, in case anyone cares. wink
Chris
'64 Chev C20 LWB stepside (Ol'Blue)
