| | | Forums66 Topics128,162 Posts1,056,951 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,859 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,859 | Do a search on this site for finding top dead center using the "positive stop" method of marking the pulley. I've written it up numerous times. You could also send me a private message and I'll share a phone number and try to walk you through the procedure. I'm a little tired of explaining it repeatedly with a keyboard! Jerry
| | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | If it is timing, it is just another example of how many carbs have been rebuilt because of ignition problems. Always start with the basics first when one obtains a new/old vehicle. Dont take for granted point gap, spark plugs/valve adjustment and ignition timing, do the easy non invasive things first then ramp up your diagnostics after that. My .02 only. Steve
1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
| | | | | Joined: Apr 2012 Posts: 158 Shop Shark | | Shop Shark Joined: Apr 2012 Posts: 158 | Steve...Makes perfect sense to analyse & diagnose.....I jumped the gun when I got it to run at 1/2 choke...I immediately went for the carb..... | | |
