3 members (Otto Skorzeny, Materman, 55shaker), 61 guests, and 1 robot.
Topics128,079
Posts1,055,941
Members48,430
#1322729 08/20/2019 6:20 PM
I have some lacquer primer left over from the past that I'd like to use up. I'm well aware of the problems associated with using it on my sheet metal in general. Im wondering if I can spray it on some of my very rusty parts that won't be very visible. I'll wire brush the rust, then coat with Ospho. After that, will it work out if I shoot lacquer on it, just to use it up?
Mike Burns
1940 Chev 1/2 ton
1953 Chev 1/2 ton
1950 Studebaker Starlight Coupe
1947 Indian Chief
1943 Indian 741
Didn't the other thread you started with the exact same question answer your question?
https://www.stovebolt.com/ubbthreads/ubbthreads.php/topics/1320906/epoxy-on-ospho.html#Post1320906
~~ Darcy
1959 GMC 9310 Canadian- built Shortbox Fleetside Deluxe
FootStomper
In the Project Journals Forum
Lacquer primer will not seal out moisture anywhere close to how well epoxy does.
The other thread that I started asked about epoxy primer over Ospho, and everybody said No, it won't work. That's why I asked about the lacquer this time.
Mike Burns
1940 Chev 1/2 ton
1953 Chev 1/2 ton
1947 Indian Chief
1943 Indian 741
