| | | Forums66 Topics128,087 Posts1,055,974 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2018 Posts: 760 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 760 | I have some lacquer primer left over from the past that I'd like to use up. I'm well aware of the problems associated with using it on my sheet metal in general. Im wondering if I can spray it on some of my very rusty parts that won't be very visible. I'll wire brush the rust, then coat with Ospho. After that, will it work out if I shoot lacquer on it, just to use it up?
Mike Burns 1940 Chev 1/2 ton 1953 Chev 1/2 ton 1950 Studebaker Starlight Coupe 1947 Indian Chief 1943 Indian 741
| | | | | Joined: Oct 2015 Posts: 338 Shop Shark | | Shop Shark Joined: Oct 2015 Posts: 338 |
| | | | | Joined: Jul 2011 Posts: 785 'Bolter | | 'Bolter Joined: Jul 2011 Posts: 785 | Lacquer primer will not seal out moisture anywhere close to how well epoxy does. | | | | | Joined: Aug 2018 Posts: 760 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 760 | The other thread that I started asked about epoxy primer over Ospho, and everybody said No, it won't work. That's why I asked about the lacquer this time.
