| | | Forums66 Topics128,047 Posts1,055,622 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2019 Posts: 83 'Bolter | | 'Bolter Joined: Jul 2019 Posts: 83 | I have just bought a 1941 pickup and it has a GMC 228 in it. The serial number stamped on the block near distributor and on the plate on driver side is: A228I54832. I have done a search on this forum and the internet to find what year the block is. I have been unable le to find ANY matching numbers. How or where else should I look?
| | | | | Joined: Mar 2014 Posts: 4,480 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,480 | Can you give us the casting number? Should be 7 numbers as I recall.
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Jul 2019 Posts: 83 'Bolter | | 'Bolter Joined: Jul 2019 Posts: 83 | GMC 2 610726 is casting # | | | | | Joined: Mar 2014 Posts: 4,480 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,480 | Ok, well...GMC casting number of 6107326 means it is a 228 (which we knew) but there should be another number (looks somewhat like a plate with two screws on each end). This number will usually begin with a letter (could be anything from A to L and this tells the month) followed by a number (will be 1 to 31 and this tells the day) followed by another number which stands for the last number of the year. I think this is on the same side of the engine as the distributor, but I won't promise that...it has been decades since I went through this hunt. I will tell you there is a problem with the final digit. If if is 0, 1, 2 or 9 then we have to guess based on the number near the distributor (and I can do this...I have saved some from GMC trucks I've owned or worked on).
| | | | | Joined: Jul 2019 Posts: 83 'Bolter | | 'Bolter Joined: Jul 2019 Posts: 83 | The number stamped in the flat area next to the distributor is A228I54832 or A228154832. I can't tell if it is a 1 or I. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Jul 2019 Posts: 83 'Bolter | | 'Bolter Joined: Jul 2019 Posts: 83 | I was able to find a site that based on the casting number iit is a 228 block used between 1939 - 1954. My concern is making sure I use the right parts (i.e...ignition) for the actual year or maybe it doesn't matter? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Can you find and post the codes? | | | | | Joined: Jul 2019 Posts: 83 'Bolter | | 'Bolter Joined: Jul 2019 Posts: 83 | Casting # 610726 Stamped# A228154832
Per the casting number I have id'd the years range of the block, but I would like to be more specific regarding the actual year .
| | | | | Joined: Mar 2014 Posts: 4,480 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,480 | Based on the numbers I have saved in my notes, I'm guessing either 46 or 47. It isn't 1950 through 1952..
| | | | | Joined: Jul 2019 Posts: 83 'Bolter | | 'Bolter Joined: Jul 2019 Posts: 83 | | | |
