0 members (), 128 guests, and 0 robots.
Topics128,035
Posts1,055,560
#1322515 08/19/2019 3:15 PM
I have just bought a 1941 pickup and it has a GMC 228 in it. The serial number stamped on the block near distributor and on the plate on driver side is: A228I54832. I have done a search on this forum and the internet to find what year the block is. I have been unable le to find ANY matching numbers. How or where else should I look?
ronsway #1322534 08/19/2019 5:04 PM
Moderator, Electrical Bay
Can you give us the casting number? Should be 7 numbers as I recall.
~ Jon
ronsway #1322579 08/19/2019 9:14 PM
GMC 2 610726 is casting #
ronsway #1322604 08/19/2019 11:54 PM
Ok, well...GMC casting number of 6107326 means it is a 228 (which we knew) but there should be another number (looks somewhat like a plate with two screws on each end). This number will usually begin with a letter (could be anything from A to L and this tells the month) followed by a number (will be 1 to 31 and this tells the day) followed by another number which stands for the last number of the year. I think this is on the same side of the engine as the distributor, but I won't promise that...it has been decades since I went through this hunt. I will tell you there is a problem with the final digit. If if is 0, 1, 2 or 9 then we have to guess based on the number near the distributor (and I can do this...I have saved some from GMC trucks I've owned or worked on).
~ Jon
Jon G #1322606 08/20/2019 12:09 AM
The number stamped in the flat area next to the distributor is A228I54832 or A228154832. I can't tell if it is a 1 or I.
ronsway #1322608 08/20/2019 12:23 AM
Here are locations of various GMC 228/248/270/302 casting codes (I think).
Post your codes and maybe members can help ID your block & head?
tclederman #1322611 08/20/2019 12:39 AM
I was able to find a site that based on the casting number iit is a 228 block used between 1939 - 1954. My concern is making sure I use the right parts (i.e...ignition) for the actual year or maybe it doesn't matter?
ronsway #1322612 08/20/2019 12:40 AM
Can you find and post the codes?
tclederman #1322615 08/20/2019 12:49 AM
Casting # 610726
Stamped# A228154832
Per the casting number I have id'd the years range of the block, but I would like to be more specific regarding the actual year .
ronsway #1322639 08/20/2019 3:26 AM
Based on the numbers I have saved in my notes, I'm guessing either 46 or 47. It isn't 1950 through 1952..
~ Jon
ronsway #1322640 08/20/2019 3:26 AM
