7 members (Hotrod Lincoln, 46 Texaco, tclederman, papas52, dt235sd, MNSmith, 55shaker),
133
0
Mod | | | Forums66 Topics128,162 Posts1,056,913 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2004 Posts: 476 Moderator | | Moderator Joined: Aug 2004 Posts: 476 | Mine is a '47 3805 panel. My vision is to keep it looking original but update the mechanicals. Back in the old Lounge forum somebody posted a link to an Independent Front Susupension manufacturer who offers something heavy duty enough and will build with the spindles you specify. I thought I saved the URL in my files of links, but I can't find it. I must have neglected to get that one before the Lounge went away. Anybody know who that is?
Also, any other good links to IFS swaps? I would go with the IFS out of a newer truck if I could figure out a decent solution to the two problems of narrowing and lowering so that it appears stock in my AD.
Don't lose your head to save a minute, You need your head, your brains are in it. Burma-Shave (1947)
| | | | | Joined: Mar 2004 Posts: 49 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 49 | If i remember right it was jim meyer racing, they have some custom kits on their site.I used a 1980 1 ton chevy under my 45 chevy.It does not sit very low still looks like a stock big truck. Hope this helps some. | | | | | Joined: Aug 2004 Posts: 476 Moderator | | Moderator Joined: Aug 2004 Posts: 476 | Hey thanks for that. I checked it out. It is not the same link as before, but they have something that looks usable. Gotta do some homework on it.
Anybody else know of a good solution for an AD 1 ton IFS?
| | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | There's a shop here in Denver that grafts front suspensions off late model trucks onto the Stovebolts. I'm thinking I'll find a donor truck someday and strip the control arms, springs, spindles, and anything related and start welding onto my '52.
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | | | | Joined: Aug 2004 Posts: 476 Moderator | | Moderator Joined: Aug 2004 Posts: 476 | Hey Hot Rod Dad,
What's the name of that shop? Do they have a website? How about an address or phone number? Any idea what they charge?
