1 members (Hotrod Lincoln),
104
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2001 Posts: 78 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2001 Posts: 78 | I have a 2001 chevy pickup with the 4.8 V8. I need more power. I want a supercharger, however I do drive this thing in the winter so I want to be able to still get around(2wd). I had this crazy idea of having a centrifugal supercharger, but on an electric clutch, like an a/c compressor, so I could turn it on and off at will. Comments? (Sorry if this is post-'72)
----------------------------------- Rollin' Hard 1946 Chevy 1/2 ton 1959 Phord 1/2 ton 2001 Chevy 1/2 ton
| | | | | Joined: Nov 2001 Posts: 38 Member | | Member Joined: Nov 2001 Posts: 38 | Jeff,
If you put a centrifugal blower on the engine you won't need a clutch. Like a turbo these blowers have a spool up and DO NOT start making boost off idle. My SEC is quicker from a dead stop with out the blower to about 40 MPH. A positive displacement blower like a Whipple is where the blower makes gobs of torque right off idle. A Vortec with a bypass valve is sucking air until the boost pressure closes the bypass valve. I don't have a bypass valve on my SEC yet so I still have the lag like a turbo set up. A blower is one of the best horsepower gains you can make dollar for dollar and installed right the blower will not harm the engine.
Steve Lemberg
1936 Chevrolet 1 1/2 ton truck 1970 Mercedes 280SE 3.5 coupe 1987 Mercedes 560SEC supercharged 1989 Mercedes 300CE 5.0 M119
