3 members (2-Ton, TUTS 59, 55shaker), 86 guests, and 3 robots.
Topics128,128
Posts1,056,685
Members48,452
#132188 07/02/2002 5:27 PM
I might be over my head, but it seems fairly straight forward. I can get a pair of axles from a K10 or K20, have them narrowed to match the factory axle widths (guy dows it local here for about $150 per axle, includes ring and pinion installation, too) , drop in a 350/TH400 with transfer case, then have custom front and rear driveshafts made. Of course, I'll have to have custom leaf springs made, but I think I could hang them in the existing locations. Any comments, or is anyone experienced in this area? Let me know if I'm off my rocker again.
I'm not lazy, I'm just pacing myself.
#132189 07/03/2002 4:08 PM
Junior Member
Junior Member
what year are you swapping to?
#132190 07/05/2002 12:01 PM
Sorry, it's a '53 3100.
#132191 07/08/2002 12:25 PM
Most anything is possible, given enough money and/or time. grin
Save yourself some money and go with an unmarried transfer case and t-350.
If at first you don't succeed, get a bigger hammer.
1941 Pontiac business coupe
1947 Chev Coupe
1969 GTO ragtop
#132192 07/28/2002 8:32 PM
I have a 53 chevy 3100 on a 64 wagoneer frame. Dana 44 axles 3.73 front and back. Manual lock out hubs. A great 4 wheel drive truck, ride height is about a normal 53 height.
#132193 08/01/2002 7:07 PM
coach ,, do you have any details with pics on your ride?
#132194 08/03/2002 3:14 AM
Mechainiac'
Try this , I am trying to set up a web page, don't know if this works or not?
http://home.attbi.com/~sworfktn/wsb/index.html
#132195 08/03/2002 7:40 AM
That is awesome cool
It looks like the rear wheel is centered really well in the wheel-well.I bet thos seats are really comfortable too
#132196 08/03/2002 3:19 PM
Thanks! Mechainiac, My son is in the process of taking photos of the upgrades we have done. We also have a new front end from a 72 wagoneer with disc brakes to install. Never enough time or money and my son leaves for college in 2 weeks.
#132197 08/04/2002 6:11 AM
Thats the best looking 4x4 conversion I have seen, CoachFrank! Does it look as if there was a lot involved in the body swap? Now, I'm real interested in how hard it was, cause I know right where there is a wagoneer of that vintage, and up here in Montana, 4WD means I could drive my panel all winter, too!
#132198 08/04/2002 4:54 PM
Thanks Andy, We bought it just for the reason you are impressed with it. Don't have photos, but will try to explain as best I can.
The frame under the bed has 4 angled mounting points... like an L on it's side to level out a mounting point,also 4 squareboxes at the corners to mount the bed to frame.All the above have been welded on to the frame All 8 are secured with carriage bolts. The running boards also have 4 L brackets welded on. The cab used the original mounting points per chevy frame. The front and rear are original 64 wagoneer dana 27 and dana 44's. Be careful here I think after 1972 the wagoneers got wider. I purchased a 72 wagoneer front end dana 44 with power steering and disc brakes to swap in. Uses 79 **** f150 rotors 5x5.5 bolt pattern to match the rear dana axle bolt pattern. The drive train is a 72 jeep pickup 360amc, th400 tranny. To change to a chevy engine I need a chevy th400 case and swap the tranny guts. Got this bit of info from Advanced Adapters. The amc bolt pattern on the th400 will not match up with a chevy engine unless this is done. Right now the 360 is running great but would like to switch to a chevy engine because of parts availibility. I guess it is time to take some new photos of the pickup and some of what I tried to explain. Will get my son on it pronto. Have any more questions e-mail me and I will give you a phone number to call me.
#132199 08/08/2002 3:42 AM
That's a gorgeous rig, Coach. Looks just like I picture an updated stocker would look-in my mind, I heard "4x4" and I thought "skyscraper". None of that stuff though. She's a beaut. Hope you fellas enjoy it.
Wannabe smile
P.S. any pics you could post of the underside I'm sure would be appreciated. Lots of guys here show interest in the frame swap idea.
"Don't expect anything and you'll never be disappointed"
#132200 08/09/2002 7:22 PM
Posted new photos on my web page, some of the frame attachment, some of the frame were to dark,will try to retake some frame shots.
