3 members (Bill Hanlon, Erniegp, festerhairball), 86 guests, and 2 robots.
Topics128,054
Posts1,055,781
#132175 02/13/2002 1:17 AM
need info on chevy head, casting # 462624.thanks guys, phil wink
Philip Bland
1961 Chevy Apache C-10 Shortbed Stepside
235 ci
1964 Chevy C-10 Custom Shortbed Fleetside 350ci
Bedford,Ky
#132176 02/13/2002 2:36 AM
Philip: GM casting/suffix number 462624, is for head 305/350 1976-1987 production years.
305- casting had 1.94/1.5 valves
350- casting had 2.02/1.6 valves
both castings have 75.5cc/76cc chambers
Hope this helps.
Think Chevy! wink :rolleyes: smile
Houston? , We have a problem!
#132177 02/13/2002 2:59 AM
Thanks Chevyman!how can i figure out the cc for the intake runners , intake cc flow, exhaust cc flow, you know,the good stuf. thanks abunck! philip grin
Philip Bland
235 ci
Bedford,Ky
#132178 02/13/2002 12:04 PM
Philip: I do not know of a reference or source to find the nominal size/flow volumes for intake or exhaust for your castings. The best I could suggest is that you take them to a Head shop. Preferably one that does speciality work and porting. They will have a buret and flow bench and could measure them for you.
The castings that you have 462624 are in reality just run of the mill SB 350 mild heads. That is if in fact, they are factory original 350, they would have the larger valves, but they would have large combustion chambers and poor port/air flow. But still, just average heads. If you are looking for performance out of your SB, there are three heads that are highly recommended by the Chevy experts, that the SB came factory equipped with. They are:
1. GM/casting number 3782461 1961-1970
283/302/327/350 1x4, 2x4, FI 62.1cc c chamber
This head with 1.94 intake and 1.5 exhaust was used in the 275,300, and 315hp 283. Also used in the 300, 340, and 360hp 327. In later 60's (65-66)
was fitted with 2.02 intake and 1.60 exhausts. Was used on later 60's 350, 365, 375hp 327's. Same head was used on late 60's Z-28 290hp 302. Same head was used on late 60's LT-1 370hp 350. In the later heads only the valve size was enlarged, the ports and chambers are identical.
2.GM/casting number 3991492 1967-1973
302/327/350 1x4, 2x4, FI 66cc c chamber
This head is sometimes called the "fuel injection"
head. Came in two versions an early 302/327/350 with straight spark plug holes. Later model was angled plug holes. This casting has the good stuff like screw in rocker studs, pushrod guide plates. Chevy engineers claimed that the angled plug gained 10hp over the straight plug version.
This head also came in two valve versions with 1.94 and 2.02 intakes and 1.5 and 1.6 exhausts.
Was used on 275, 290hp 302. The 300, 340hp 327. Was also used on 325, 360, 370hp 350.
3. GM/casting number 340292 1973-1980
350 1x4 and FI 66cc c chamber
Called the "Turbo" or turbo angled plug head.
Came only with 2.02 intake and 1.60 exhaust.
Have screw in studs, guide plates, larger spring seats, and larger ports. No heat crossover passage. Usually equipped with the larger springs.
On top the valve spring seat was enlarged from 1.28 inches to 1.44 inches. Also has enlarged ventilator openings (pushrod openings) for increased crankcase ventilation. The combustion chamber in the 292 head is identical to the
461/492 castings.
There you have it, hope this helps.
Think Chevy! :p grin :rolleyes: smile :p grin
#132179 02/13/2002 5:28 PM
Kelly
1951 Chevy 3100
1967 RS/SS Camaro
#132180 02/14/2002 5:41 AM
Years ago Hot Rod magazine flow tested and ranked Chevy iron heads. I recall that the 461 head flowed the best with the 993 being a close second. I put 993s on a pickup I threw together and it really ran good. I cannot find the issue this was in but I will keep looking.
Remember 9-11-01--God Bless the USA
JUSTICE, not REVENGE, will prevail
1951 Chevy 1/2-ton Pickup truck
#132181 02/14/2002 6:42 PM
Racecarl,
I have 993 heads here at home, as well as 882. They do both look exactely the same, both lightweight cast, both crack prone, the ports looks the same. Both with big 76cc chambers. Used for a long time a pair of 882 on a high performance Caravan here (Caravan in brazil is a small chevy station wagon, no minivan) but them swapped them for a pair of 441. Much better heads, smaller 69cc chambers, the exhaust port looks a li'l bigger.
I'd not use a 882/993 if I could use another. After a long time I got a pair of 461, and I'm into removing the engine and rebuilding it all over again just cause of the 461. Would like to have a set of TFS or any other aluminum head, but cash is a li'l short these days.
Alexandre Garcia
#132182 02/15/2002 3:24 AM
hey, thanks for the info guys, just trying to get all the info before i start this rebuild.Block and heads, and crank is going to machine shop tomarrow.philip wink
Philip Bland
235 ci
Bedford,Ky
