1 members (2-Ton), 167 guests, and 3 robots.
Topics128,088
Posts1,056,114
Members48,434
#1321449 08/11/2019 6:03 PM
So can anyone tell me the dimensions of the front pinion bearing for a 53 1/2 ton pick up. I believe it’s called bearing number 5306 OD and ID of the bearing its self, thank you for your help
3B Offline
Hy posey, by going to my search engine and typing Timken 5306 bearing dimensions I got bore 30MM, outside diameter 72MM and width 30.17MM, hope that helps.
Yes that helps thanks
