1 members (Mike Roache),
58
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,078 Posts1,055,938 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2018 Posts: 760 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 760 | Yesterday I went to several auto parts stores looking for a gallon of Aircraft stripper (paint remover). Finally, a friendly counter man at my usual store, told me that the government has outlawed it, and they won't be getting anymore. Since nobody had it, I'm assuming this is true. So, I'm curious, are there any other chemical strippers available that work well on auto paint? I have a sandblaster & other tools that will work too, but sometimes stripper is good. Let me know.
Mike Burns 1940 Chev 1/2 ton 1953 Chev 1/2 ton 1950 Studebaker Starlight Coupe 1947 Indian Chief 1943 Indian 741
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Aug 2018 Posts: 760 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 760 | I'm pretty sure that Klean Strip is the stripper that I've used in the past. It's the same one that I was told was no longer available yesterday. It always worked well for me in the past. If somebody knows who might still stock it, I'd like to know.
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | I can't find any stores who don't have it. I just Googled "Aircraft Stripper". Pep Boys, O'Reilly's, Autozone, Advanced Auto, Amazon, Walmart............ Kleen Strip brand and Rustoleum brand........... May have changed the formula to "Citrus" but it is still available.......
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: May 2015 Posts: 11,052 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,052 | I browsed around Tim's link and see that they have a whole laundry list of discontinued products, including AIRCRAFT® Non-Methylene Chloride Paint Remover, although it appears the Aircraft stripper is still available. However, their "Find a Retailer" link doesn't work.  You might try an automotive paint distributor, not a standard auto parts store.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Google search on Aircraft Paint RemoverIt looks like some of these products are what you want? Part#: GAR343 (gal) or: Part#QAR343 (qt) or: Part#EAR322 Pep Boys Advance Auto Wal-Mart (at least by on-line order) | | | | | Joined: Aug 2018 Posts: 760 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 760 | The stores that you guys mentioned still have the aircraft stripper on many of their websites, but these are mostly the same stores that I visited a couple of days ago, and they did not actually have it on the shelves of their stores. All of the employees that I talked to seemed surprised that they didn't have it. I'll have to admit though that I did not check O'Riley, or Pep Boys, only because I didn't have them nearby. I'll stay after it.
| | | | | Joined: Oct 2015 Posts: 338 Shop Shark | | Shop Shark Joined: Oct 2015 Posts: 338 | The EPA has forbidden many of the most important ingredients of Aircraft Stripper. Klean Strip was the only manufacturer for many years and in fact made it for 3M and others.
Just as well, because I'm not a fan of introducing chemicals and then ample amounts of water to steel you plan on painting.
| | | | | Joined: Dec 2014 Posts: 678 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 678 | Try graffiti remover. Comes in liquid, gel or spray. It even removed the factory tar coating inside my Model A doors.
1951 Chevy Panel Truck
| | | | | Joined: Jun 2001 Posts: 793 Bondo Artiste | | Bondo Artiste Joined: Jun 2001 Posts: 793 | I have bought it from Advance Auto Parts here in VA through the years without issue. In fact I have can on the shelve, bought 6 months ago.
It's a nasty product, But get's the job done. Wear your proper protection, respirator and use in a well ventilated area.
~ Phillip 1949 GMC Suburban - 10 year project 1952 Pontiac Chieftain Convertible straight 8 hydramatic 1945 GMC half ton truck - Driver- Sold 9-15-25 1946 Chevy COE - SOLD 1-5-26 BUH BYE CHEVY! 1959 GMC Half ton long bed NAPCO | | | | | Joined: May 2006 Posts: 934 'Bolter | | 'Bolter Joined: May 2006 Posts: 934 | Bought aircraft stripper from O Reilly’s. Not the same product that it once was because it does not coontain methylehatever anymore. Nonetheless, takes longer to lift paint, and dries faster than its capability to lift paint. The key is: brush it on one-way only, and just one or two brush strokes. Then cover with plastic kitchen wrap to prevent it from evaporating and drying. It required 15 minutes or less wait time in the past. Now it requires 30-46 (maybe 47 minutes) minutes but who’s counting? Wash as directions say, then wash with lacquer thinner or solvent to remove wax binder - if wax remains expect fisheyes in your paint or compromised adhesion.
