3 members (Southerntruck, 2-Ton, 1 invisible), 78 guests, and 3 robots.
Topics128,142
Posts1,056,491
Members48,442
#132051 10/30/2004 1:35 AM
Junior Member
Junior Member
HI ALL ....first i'm going to prostreet my truck ...a 1950 chevy..31x18.5..i'm planning on useing a 92 sub. chassis...anyone have any other chassis ideas??...this chassis is a freebe ...i paid nada for it ...the chassis is nice and flat and already for a body ..my orig. chassis is all orig.. w/216 and running gear ,,think i'll have a problem selling it ???i don't want to modify it for someone might be able to use it for a ground up restore.........regards.....gary
#132052 10/30/2004 2:39 AM
You'll have trouble selling the original stuff for much. You might find someone who wants it, but unless they are local the cost of transporting it is likely to scare them off.
When you say '92 sub do you mean a Suburban? Check the track width on the front suspension. I think you'll find its just a little wide for your '50.
If I were thinking pro street I think I'd look for an S-10 chassis and suspension. The front suspension will fit better under the '50.
#132053 11/08/2004 5:35 AM
Junior Member
Junior Member
OldSub gave some good advice, but might the Suburban chassis be a tad too long, too? Cutting frames=major headache + potential legal problems.
Did I say that out loud?
#132054 11/09/2004 8:11 AM
92 frame
This looks like a pretty good fit albeit a little wider than original.
#132055 11/09/2004 9:06 PM
Quote
Originally posted by GMONIZ:
92 frame
I'd want to see and drive that one before buying it. The axles should be too wide and I suspect it has interference problems. I don't know the wheelbase for the '92, but unless its 116 inches or maybe 117 inches it would need to be changed.
Lots of people say the best frame is the one your truck came with. I won't say that, but I'll agree that a frame swap is not for the ill-informed or faint of heart. Do your homework first!
#132056 11/11/2004 7:53 AM
Oldsub, I asked the seller and he responded.
"You asked:
"How many modifications were done to the frame to get it to fit under the panel? How does it steer and do the tires rub the fenders? What is the overall length and wheelbase of the original 92 frame?"
The frame came from a short bed reg cab pickup. I didn't have to change the length of the frame. I had to move the engine back 4". The rear of the body sits right on the frame rails. I had to make some mounts to mount the front of the frame. The right front tire was rubbing on the fender so I adjusted the torsion bars and it dosen't seem to rub any longer. It steers fine. Thanks, Jeff"
It may be ok for those who like the 4 wheel drive look, but I agree more homework is needed. I jsut thought that it was an oportunity to see another frame modification.
#132057 11/11/2004 9:58 PM
GMONIZ I'm glad you asked. I've seen a couple old trucks lifted with later 4x4 running gear under them, and its just not the look I want either. But every time I get close to one I look underneath to see how they did it.
