5 members (jmoore, Bill Hanlon, 3B, 54farmtruck, Phak1), 95 guests, and 1 robot.
Topics128,188
Posts1,057,329
Members48,469
Hello, I thought I had real nice rims for my 1933 Chev 1.5 ton so I went ahead and bought 6.00x20 tires ,tubes and flaps, Unfortunately only to find out that when I pulled apart the old tires the rims a rusted away junk so I need 3 or 4 locking rims with 10/7.25 stud circle with-5/8ths holes and a 4.75 center hole I live in SE Wisconsin
Crusing in the Passing Lane
Brad,
First tubeless tires came out in the late '50's, 22.5" rims with that bolt pattern on GM trucks are available, hard to find, look on farm trucks, need to make spacer sleeve to use the modern wheels with slightly larger hub mounting hole. Modern 9 x 22.5" tires fit OK.
Unfortunately you have a set of 20's, perhaps you can find someone who needs them; only other option is to keep searching for good 20" wheels.
While you are looking for 20's, keep an eye out for some 22.5's, might take a while for either. Sometimes one finds one or two mixed on a truck.
Ed
They are tough to find. I need three as well for my 40. The shipping kills you if you can find them. I have run across wheels but they are the RH5 or split rims not lock rings. I always have asked for good photos. That tends to stop progress.
Harmon.
[img]https://www.stovebolt.com/ubbthreads/ubbthreads.php/ubb/download/Number/10172/filename/33 chev 3.jpg[/img][img]https://www.stovebolt.com/ubbthreads/ubbthreads.php/ubb/download/Number/10172/filename/33 chev 3.jpg[/img]Thought the resto Gods smiled down on me as yesterday standing in a neighbor's cow yard, I noticed a trailer with 10 hole wheels. upon closed inspection I found out they would work for my 33 guest. I inspect the locking rim area and they look nice. Oh,,,,, the Resto God is a trickster as upon taking the rims to the tire guy I find out that I must inspect the area where the rivets hold the inner piece of to the outside rim circle. My scrap buddy is happy though and I at least have 4 rims to put the truck on the ground. Hopefully... the dumper will not be a hover craft for long[img]https://www.stovebolt.com/ubbthreads/ubbthreads.php/ubb/download/Number/10336/filename/thumbnail.jpg[/img]
the saga continues,,,Kinda fell into these, 4 NOS rims are off to the sandblaster/tire guy tomorrow. Whew this is getting expansive!!!!
Red dot, center of chest ...
You don't know the half of it.
Paul Schmehl CI 6
geek@stovebolt.com
Stovebolt Staff: Geek
rims and tires on!!!!!!!!!!!
new shoes all around
whoops
Even upside down it looks awesome. What a truck ! Nice wheels and meats, also.
Tony
1942 Chevrolet 1 1/2-ton (G-506 Military) Panel
Short video
Longer video
Big Bolt Forum Moderator
great progress!! glad you found some rims!
Mike
Is this truck in Oz?
Ed
