| | | Forums66 Topics128,138 Posts1,056,440 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2001 Posts: 17 Member | | Member Joined: Aug 2001 Posts: 17 | I ended up buying a complete chassis with an actual m2 IFS that has been professionally cut and welded onto the frame. The guy that did it has an excelent reputation so I'm not worried about the workmanship, just details like proper sizing and fit. The FE was welded on a bit forward due to the new suspension being much lower than before.
Is there anything I should be aware of, since this was not a "kit" specifically made for the truck?
I got the whole thing, complete with disks and a rebuilt rear end for only $400. The chassis belonged to a truck that was partially built when parked next to a huge stack of hay. The hay caught on fire and the truck was burned bad. The owner gave the truck back to the guy that built it because of debt, then I bought the chassis from him just to "get it out of the yard." Hopefully it was a wise choice. | | | | | Joined: Mar 2000 Posts: 1,181 Red dot, center of chest ... | | Red dot, center of chest ... Joined: Mar 2000 Posts: 1,181 | For the money you've got in it, how could you go wrong? | | |
