| | | Forums66 Topics128,049 Posts1,055,635 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2001 Posts: 182 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2001 Posts: 182 | [img]http://photo.starblvd.net/~Russntustin/1-1-1.jpg?i=1058367920&pw=*66993EF05BEE[/img] | | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Smallblock in an AD Chevy truck
| | | | | Joined: Jan 2002 Posts: 398 Member | | Member Joined: Jan 2002 Posts: 398 | Russn-that your truck? Did you have a hard time finding those "Chevrolet" script valvecovers? Wonder if anybody's done a repro of 'em yet-they're cool! Regards, Wannabe
"Don't expect anything and you'll never be disappointed"
| | | | | Joined: Nov 2001 Posts: 182 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2001 Posts: 182 | Oh geesh Mechanic...you past the test ! I was testing to see if I had learned to post a pix. Wannabe: We have alot of swapmeets in this area..lots of em around. I like the covers alot, but the engine wasn't breathing enough for me so I went with some breather covers. I was getting too much blow-by out the filler tube.  | | | | | Joined: Sep 2002 Posts: 438 Shop Shark | | Shop Shark Joined: Sep 2002 Posts: 438 | Russ-
I that your new fan shroud? I thought you initiated a thread about shrouds. Which way did you end up going?
Looks great! | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Russ, what a great pic. I really like that Holley. It brings back great memories! | | | | | Joined: Nov 2001 Posts: 182 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2001 Posts: 182 | 51Phatboy: Yes that's the shroud I wound up with. I found it at a swapmeet for $5. It fits pretty good with a little trimming. I was able to make some simple brackets for it. And it works .It made a good difference. (I also lowered the radiator 4" and in 1".I can't tell you what the shroud's from...I just walked around the swapmeet with a little tape measure and found this one. I really didn't want to use plastic ...but it turned out OK. | | | | | Joined: Sep 2002 Posts: 438 Shop Shark | | Shop Shark Joined: Sep 2002 Posts: 438 | | | |
