1 members (MikeE), 70 guests, and 2 robots.
Topics128,031
Posts1,055,436
Members48,422
#1318158 07/18/2019 12:09 AM
JD1
Offline
I just picked up this visor (pictures attached).
Can anyone tell me what model it is? I had it all apart and didn't see a model number on any piece listed anywhere. I also searched all the Fulton threads and didn't see any models listed or instructions posted up. I think this visor is an 800 and I think I know how to adjust it, but I would like to get the instructions to make sure I adjust and mount it correctly.
JD
1951 Chevy 3100 1/2 ton (1957 235, 4 speed, 411 rear)
JD1 #1318238 07/18/2019 1:59 PM
Looks like a 800.
There should be/will be two center mounts that clamp to the windshield center strip also.
There is a discussion on this from December 2018. Has all the measurements you would need.
I have one on my 51 3100, and I like it.
Mike
1951 3100 5 window
kades51 #1318252 07/18/2019 3:38 PM
JD1
Offline
Mike,
Thanks for the reply.
Yes, it has the center mounts. I think there is tightening nut and bolt missing off the center piece though.
I saw the thread where you gave your measurements. That helps.
Could you take a picture of the dog bone mounted on the truck?
I wanted to read the install instructions if someone has them to make sure I have everything and how to adjust and install it correctly.
My visor came disassembled. If anyone knows what holes they used on the metal rods, that would help me on the width adjustment.
Joe
JD1 #1319115 07/24/2019 9:07 PM
When I assembled mine I measured the distance between the gutters at the top of the doors at about window height, then slipped the rods into the top and bottom of the shield, and slid them back and forth until the measurement was right and both sides had the same amount of rod exposed. Then I put the screws into the closest holes. It ended up fitting fine. Once I had that part lined up I installed the center section. ended up looking good, at least to me.
Tim
I am currently digging back in to a 1953 3800 (one ton) with a nine foot bed. I've owned it since 1979, and drove it until 1982 (or so). My wife got me involved in restoring it back in 2002, got the body removed and the frame redone, then things came up. Now I am retired and starting again. If anyone is interested I have photos on Imagur ( https://timwhiteblues.imgur.com/ ). I live way back in the woods in the Ozarks on 40 acres at the end of a 2 1/2 mile private road.
Tim
JD1 #1319168 07/25/2019 10:36 AM
I have some visor instructions I downloaded at one time. If you send me your e-mail address I will scan them and send you a copy.
