3 members (Materman, blanch53, 1 invisible),
125
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2017 Posts: 480 'Bolter | | 'Bolter Joined: Apr 2017 Posts: 480 | I'm finally getting ready to start putting my bed together, but all the information I've been able to find seems to be for 1/2 and 3/4 tons. From what I've seen, thry have the cross sills already on the frame when they put the bed on. But that doesn't seem right to me for my one ton. It seems to me that the cross sills should be bolted to the bed sides before the bed is installed on the frame.
Does anyone have good directions for this? The bed is heavy enough that I don't really want to be putting it on and taking it off more than absolutely necessary. Hints, tips, and advice wlecome.
Tim
I am currently digging back in to a 1953 3800 (one ton) with a nine foot bed. I've owned it since 1979, and drove it until 1982 (or so). My wife got me involved in restoring it back in 2002, got the body removed and the frame redone, then things came up. Now I am retired and starting again. If anyone is interested I have photos on Imagur ( https://timwhiteblues.imgur.com/ ). I live way back in the woods in the Ozarks on 40 acres at the end of a 2 1/2 mile private road. Tim
| | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | I only have a 1/2 ton but i think you have to bolt the cross members to the bed then place in the frame. I n my case I built the whole bed on saw horses and then backed under it and lowered on to the frame. Then taking a floor Jack i raised each point where a wood block was located and inserted the eccentric washer and bolt from the top through the wood through the cross member through the wood block into the frame. Repeated f or all six in my case then fine tuned the bed position and tightened all the bolts. | | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | I also second assembling it on the floor and then putting it on. There is less chance of banging a cab skin or dropping a box side. Plus, with the 1 ton (as I have) as the sills are bolted to the bed side and this provides very good pickup points. I have a homemade overhead crane with two chainfall hoists on it. I used 4 ratchet straps at 4 corners and this enabled me to pick hat bed up laser level, roll the truck under it, and very easily, precisely and independently install the bed myself. Once on, readjust as necessary, but if you took your time on the floor and it’s square, it should slide right down and on.
| | | | | Joined: Jan 2006 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2006 Posts: 35 | I just completed the 9ft bed installation. Didnt quite understand the question. | | | | | Joined: Jul 2014 Posts: 892 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 892 | About 20 years ago I redid all the sheet metal on my 3800 PU. I unbolted the box assembly minus fenders, jacked it up and drove out from under it. It immediately crashed to the ground because of dodgy sawhorses and uneven ground on a hill. I couldn't have maneuvered the assembled box into position to back under it for the above reasons. So, I assembled it, already painted, one piece at a time on the frame. This worked out fine and I needed help only to position the sides and get a couple of bolts started. didn't scratch anything. All that aside, I didn't get the cross sills exactly centered but I have been able to run 255/85x16 tires anyway though the tire on one side is closer to the box.
BTW I couldn't get cross pieces for the 1 Ton so I had to weld in repair sections. No problems in 20 years. 1951 3800 1-ton"Earning its keep from the get-go"In the DITY Gallery1962 261 (w/cam, Fenton headers, 2 carbs, MSD ign.), SM420 & Brown-Lipe 6231A 3spd aux. trans, stock axles & brakes. Owned since 1971. | | |
